Thread: Just completed my top swap..first test drive left mewith concers...
Results 21 to 40 of 66
  1. #21 Re: Just completed my top swap..first test drive left mewith concers...
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Supercharged is very strong and I've heard and seen people making good amounts of power with them. NA is a little more susceptible to failing under the increased load. Rods are thinner and pistons don't hold up Well When you make mistakes....like me.
  2. #22 Re: Just completed my top swap..first test drive left mewith concers...
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    rods are thinner on series III engines, I have series II so Im good there hopefully..
    Im glad I live near overkill, he can tune this in for me.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  3. #23 Re: Just completed my top swap..first test drive left mewith concers...
    Feb 2009
    flintnasty MI
    I have yet to blow up any motor except for a L26 which was making 550+whp. Blowing up any motor with a M90 takes a special skill.
  4. #24 Re: Just completed my top swap..first test drive left mewith concers...
    Donating User Odi's Avatar
    Chicago South Suburbs
    only issues, other than people using ****ty abused parts to swap, is with l26's. if you have a l36 and plan on top swaping, you should be fine.
  5. #25 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Well When I rebuild I'm using an L36 bottom then.
  6. #26 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Hey now. Come on I'm a rookie lol. Cut me a little slack.
  7. #27 Re: Just completed my top swap..first test drive left mewith concers...
    St Thomas Ontario
    Yq I lucked out with impalas stocking with the l36
  8. #28 Re: Just completed my top swap..first test drive left mewith concers...
    Feb 2009
    flintnasty MI
    Abused? I cant stress enough how durable 3800s are when it comes to power handling... I havent given my cars any slack at power levels that double and triple your best m90 "builds".... if you are breaking stuff (L36/L26/L67/L32) from "too much power" at 300whp you are insane.
  9. #29 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Well picking up a 3.6 pulley soon....so....:-P
  10. #30 Re: Just completed my top swap..first test drive left mewith concers...
    Pennsylvania, USA
    In terms of rod strength: L32>L67>L36>L26. Except for some lucky bozos that got 2004 N/A's with L36 rods.
  11. #31 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    I'll always consider the L32. It's what I'd like to end up with, but I enjoy the idea of the top swapped 3.8 as long as I'm boosted via the M90. Turbo....yeah L32 all the way.
  12. #32 Re: Just completed my top swap..first test drive left mewith concers...
    Quote Originally Posted by jlgp2007nc View Post
    I've got about a thousand miles out of it already and last night was the first time I really opened it up. I haven't driven the car yet but When I put in a new plug it idled just fine. We'll see what happens When I put it on the road this afternoon.
    I'm not surprised about the failure I did hit 11psi and leaned out to 12.1:1. I already know the NA bottom ends aren't prepared for what the top swap is throwing out.
    Be afraid lol....top swapping high mile stock NA bottom ends will always inevitably lead to engine failure. All you can do is do a good job at install, keep everything clean, torque everything down properly and use good parts.
    I'm not out of the game just yet!
    You do know that SC bottom ends do the same thing, right? Any high mile bottom end or bottom end exposed to coolant is at risk of premature failure.
  13. #33 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Lol Yes I know. Can be rebuilt.
  14. #34 Re: Just completed my top swap..first test drive left mewith concers...
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    I've blew up 2 L36 motors... TWO!!! Without a supercharger on either one... Here's a pic of the last one... I can see right through the block... lol
    http://i698.photobucket.com/albums/v...4-12163521.jpg
    http://i698.photobucket.com/albums/v...4-12163534.jpg
    http://i698.photobucket.com/albums/v...4-13192807.jpg
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  15. #35 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Dayyuummnnnn. What did you do? Lol
  16. #36 Re: Just completed my top swap..first test drive left mewith concers...
    Nov 2009
    Tennessee
    I was driving up the mountain I live on... Not getting on it, nothing excessive... I braked to go around a hairpin, went around it, proceeded to give it gas and POW!!!! Good bye motor #2. My first motor, the original, threw #1 rod (as did motor #2) but #1 did not throw it through the block. It just dropped the remaining part of the arm and it locked up on the crank. Do I swear by L36 rods..... NO To each their own, I'll take my chances on the L26 PM rods... If I blow the L26, I'll go LS... LOL
  17. #37 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Well mine blew today. Freaking part throttle and 8psi too. Was running fantastic...ugh. No boom, but knocking and spitting out blue and black smoke.
  18. #38 Re: Just completed my top swap..first test drive left mewith concers...
    gardner,mass
    ouch
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  19. #39 Re: Just completed my top swap..first test drive left mewith concers...
    Omaha, NE
    You were running 11.7 AFR on 11psi with what for supporting mods???
    I had a 3.4, XP, Header car that I had locking at 10.1 afr WOT on 91 E10/E15. On the rich side, yes, but my engine was happy, and it took a good amount of abuse the 2 years I had it topswapped. As a matter of fact, its back to N/A and still running to this day.
  20. #40 Re: Just completed my top swap..first test drive left mewith concers...
    Sep 2012
    North Carolina
    Was supposed to be 11. Was still maf tuning to drop the numbers and thought I'd get a nice little pull out of it and wham. Wasn't even beating on it that's what sucks.
  1. final drive gear swap
    By rbob900 in forum General Grand Prix Discussion
    Last Post: 04-02-2013, 06:23 AM
  2. Left Rear Locks up When in Drive But Not in Reverse. Why?
    By burgundybullet in forum General Tech Discussion
    Last Post: 03-06-2013, 11:12 AM
  3. Test Drive Gone Bad?
    By blueguy in forum General Tech Discussion
    Last Post: 04-19-2009, 02:23 AM
  4. Pics from My recently completed Top Swap!!(no 56K!!)
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 07:12 PM
  5. Differential COMPLETED!!
    By JCGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2008, 10:56 PM
