Thread: LTFT pegged at 16.4
Results 1 to 20 of 33
  1. #1 LTFT pegged at 16.4
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    would a big exhaust leak cause this?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  2. #2 Re: LTFT pegged at 16.4
    Vacuum leak.
  3. #3 Re: LTFT pegged at 16.4
    Topeka, KS
    Vacuum leak.
    x2! Check your gaskets on the Throttle body and all your vacuum lines. Spray brake cleaner around them and if the idle changes and your LTFT goes up you found the source.
  4. #4 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    so a exhaust leak would not cause this excessive of a difference?
    Ohio
    If it's before the first o2 sensor it will. I was leaking right at the collectors on my front header, left me at 16.4 all the time. Fixed the leak, back down around +5
  6. #6 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    well my cam makes it very hard to notice idle changes. VERY lopey
  7. #7 Re: LTFT pegged at 16.4
    Grand Island, Nebraska
    Ususally vacuum leak will cause + fuel trims, Exhaust leak will cause -. Replace the SC lately?
    Buffalo
    Evap opened , has a leak. Goes away when closed. Just a thought.
    While its running, pull the line going to the solenoid and see if the solenoid is sucking air. If it is, it's open. Plug the line going back to the motor and see in real time the trims settle
  9. #9 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    Quote Originally Posted by crazyguy03 View Post
    i recently deleted the evap system and plugged the tb vac nipple, i deleted it trying to fix my fuel trim. no dice..
    replaced my vac lines to boost solenoids, they are all new, new t's and lines.
    i had to take apart the top end for a rebuild, new gaskets everything.
    also why would a exhaust leak give negative fuel trim?? anything under 0 is leaning out your afr. if you have a exhaust leak, it reads extra oxygen, at that point it would add fuel, not take it away.
  10. #10 Re: LTFT pegged at 16.4
    Feb 2009
    flintnasty MI
    you have an NIC cam... It is an exhaust leak. Unplug the narrowband and go on with life.
  11. #11 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    lol unplug my o2 sensor? ur a animal...
    Buffalo
    Yes. He's suggesting u run off commanded AF/R
  13. #13 Re: LTFT pegged at 16.4
    open loop.
    hope your fuel/air models are accurate unless you like carrying your tuning software around with you.
  14. #14 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    i dont have any tuning software at the moment, and having a hard time getting zzp to get back to me about what the commanded afr is and if i could run in open loop.
    i asked my instructor about it as well, he said i could if i was tuned for it, but being its a canned tune, not a good idea.
    i did a WOT 1 and 2nd gear pull and i got 6.6lbs of boost. is that a normal number for my flow mods with a 3.5 pulley? if its normal, then it cant be a vacuum leak. one large enough to peg my LTFT would drop my boost, yes?
  15. #15 Re: LTFT pegged at 16.4
    Feb 2009
    flintnasty MI
    i havent had any problems running NIC stuff on a stock tune. what does the wideband say / what are the LTFTs at cruising/wot?
  16. #16 Re: LTFT pegged at 16.4
    Mar 2012
    Dallas
    dont have access to scanner at the moment, but did find something interesting, when i move my egr valve, you hear a sucking sound...
    so now i have to source a new egr valve, i dont want to delete it and then start knocking bc of higher cylinder temps. i definitely smell heavy exhaust fumes around that area, but could be coming up from under the car where my large exhaust leak is.
  17. #17 Re: LTFT pegged at 16.4
    Feb 2009
    flintnasty MI
    "move" your egr? as in the tubes going to the intake and the exhaust?
    If you can delete the EGR, it will only help you. Only thing it does is improve emissions at cruise, maybe.
    Buffalo
    Question. How does deleting hot exhaust fumes from entering your intake manifold RAISE cylinder temps?
  19. #19 Re: LTFT pegged at 16.4
    Mar 2012
    NC
    The EGR recirculates spent exhaust gases back into the combustion chamber. Being that there is little to no oxygen content in the exhaust stream, all that's really there is some unburned fuel. The fuel can only mix with the oxygen brought in during the intake stroke. Thus, since there is no oxygen, there is less burn and lower combustion temps during cruise.
  20. #20 Re: LTFT pegged at 16.4
    It doesn't.
    It REMOVES hot air from the intake side LOWERING intake temps and killing the carbon build-up that always is associated with EGR. People claim EGR hurts MPG's...I never saw a loss in MPG's, people just like to b1tch.
    There's your problem and your vacuum leak. Just block it off with two pennies and some RTV so you don't have to worry about it again.
  1. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  2. temp gauge pegged
    By PatriotGT in forum General Tech Discussion
    Last Post: 08-29-2010, 04:10 PM
  3. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  4. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
