Thread: Air fuel controller 2004+ Grand Prix
Results 1 to 10 of 10
  1. #1 Air fuel controller 2004+ Grand Prix
    GTX Level Member colindunn's Avatar
    Aurora, IL
    Zzp sells some stuff... Is there a good afr controller for 2004 and newer gtp's? Didn't know if anyone had any knowledge on this. Thank you.
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  2. #2 Re: Air fuel controller 2004+ Grand Prix
    I call it a tune, set AFR to 11.4 and done.
  3. #3 Re: Air fuel controller 2004+ Grand Prix
    Aurora, IL
    Well I don't have a tuner..
  4. #4 Re: Air fuel controller 2004+ Grand Prix
    The way I think about it, is that a controller isnt the best idea, there is a little more to setting up the correct AFR than just using a knob to change it.
    The car stock already runs somewhat rich, around the 11's for AFR, with the amount of mods you have, you should be getting a custom tune to dial everything in.
  5. #5 Re: Air fuel controller 2004+ Grand Prix
    Aurora, IL
    Didn't know if there was something besides hp tuners. Something that just adjust the maf and afr.
  6. #6 Re: Air fuel controller 2004+ Grand Prix
    i had an AFC.
    it allows you to scale the MAF tables by percentage, essentially changing the fueling tables by tricking the PCM into seeing you ingesting more air into the motor. it works for small tweaking and is helpful for when you run out of room and max out the MAF (because you can scale it back down).
    it's not a replacement for a good tune.
  7. #7 Re: Air fuel controller 2004+ Grand Prix
    Aurora, IL
    Nobody in my area that tunes..
  8. #8 Re: Air fuel controller 2004+ Grand Prix
    start looking around. there has to be someone within a hundred miles or so...
  9. #9 Re: Air fuel controller 2004+ Grand Prix
    Feb 2009
    flintnasty MI
    get a wideband and see how broken your car is. After that scan it and see what the LTFT's are doing. You probably dont need a tune, most people dont unless they are changing out alot of parts.
  10. #10 Re: Air fuel controller 2004+ Grand Prix
    Aurora, IL
    I already have a wideband. Everything is where it should be. Fuel trims are within spec currently as well. But I would like to drop to a 3.2 pulley with 42# injectors and I know I need to tune it at that point. If I threw the 3.2 on right now it would be running way to lean.
  1. 2004 grand prix fuel pump access door
    By gsi30 in forum General Tech Discussion
    Last Post: 10-24-2012, 08:25 PM
