Thread: Wideband question
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Wideband question
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I'm buying a wideband today and need to know if anyone can tell me what will be the issues on my car if I remove the rear o2 sensor instead of putting a new bung in place? I already don't have a cat so I was just wondering what the ill effects would be.
    Also do I have to remove the wideband o2 when not tuning or does it just stay mounted.?
    And yes I've searched read lots of info just couldn't find these answers.
    I was thinking of going with an AEM.. Any other recommendations? I see an AEM failsafe is that worth the extra cash?
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: Wideband question
    Arizona
    Well for one hour rear 02 is after your cat so your readings won't be accurate the wideband should be closest to where your pre cat sensor as possible. It should also never be on the bottom of the exhaust pipe either. As far as leaving it in it shouldn't be left in without the heater circuit active. Aem NGK and innovative are all good brands
  3. #3 Re: Wideband question
    Oct 2011
    MI
    I have no Cat so shouldn't be any different than the front reading correct?
    So a wideband o2 only has two wires then? Or you have to wire them into the heater circuit to leave them in?
    Also if I did place it in the rear o2 spot will the car trip out or not run right if its unplugged.?
  4. #4 Re: Wideband question
    In reality you want it as close to the stocker so that it's in the hottest mixed (front/back) exhaust you can get. By putting it in the rear location it would be getting colder exhaust.
  5. #5 Re: Wideband question
    The wideband has 4 wires, and its its own sensor and gauge.
    You want the sensor in HOT exhaust gases, all the way at the rear o2 is too far back IMO for the sensor.
    It stays on all the time because its a gauge.
    I would either go with a NGK AFX or a LC1 wideband, a AEM can be used just fine, just know that its not as spot on as a NGK AFX. It may be off by .1 to .2 at all time, which to many isnt a huge deal, but for some it is.
    The wideband reads in numbers from 10-17.9, unlike a o2 sensor that reads MV from say 05-999. Say when its reading normal and acting like a o2 sensor the numbers bounce from 14.3 to 15.3ish as the car is trying to reach stoich.
    Here is how mine looks, its a AEM style, bottom gauge.
  6. #6 Re: Wideband question
    Oct 2011
    MI
    Gotcha so close as possible to the front sensor. Have a bung welded in. And it must be wired into the heater circuit.. Easy enough
    I have plans to buy the $200 AEM more than likely... Is the failsafe gauge any more accurate or worth the extra $100 for what it does? Just wondered
    Edit. Found the AEM failsafe for 250, the normal aem for 150 and the innovate for 159
  7. #7 Re: Wideband question
    You don't have to tap a wire anything. Nothing, zip, zero, nada.
    You leave the front o2 sensor alone, don't touch it.
    The wideband is its own sensor, it comes with everything, its own wire loom the works. All you have to do it run the harness inside the car and supply a 12v power to the gauge itself.
  8. #8 Re: Wideband question
    Arizona
    but in order to log through HP tuners since you have the standard version youll need to run a wire to your EGR signal output.
  9. #9 Re: Wideband question
    Oct 2011
    MI
    Here's what I have what do i need to do then to log with the wideband because you just confused me with the egr wire..
  10. #10 Re: Wideband question
    Oct 2011
    MI
    I just thought the blue wire went to the wideband
  11. #11 Re: Wideband question
    Arizona
    holy **** i thought i read you had standard well in that case the outpus for the wideband controller plugs directly into your HP tuner interface all you need to do is calibrate your wideband and get your voltage offset and youre golden
  12. #12 Re: Wideband question
    I don't even log my wideband, I just watch it lol.
    Because lazy.
  13. #13 Re: Wideband question
    Oct 2011
    MI
    Yeah pro version I guess I didn't read that right. I just wanna do the tune one time . right now I'm ordering a 3.6 mps and this wideband.. But yeah while I might not be watching it while I drive passengers always seem to be so amazed at gauges lol.
    I almost want to go with a 3.5 but I'm not a big fan of risking Kr. Even though my scans so next to nothing stock pulley
  14. #14 Re: Wideband question
    Arizona
    you should definatley invest in a intercooler man
  15. #15 Re: Wideband question
    You will be all set. When you hook up the wideband in the cabin, put another ground off the ground source, run that and the output to the HPT green thing. Then setup a pid for the wideband you use. (easy search on HPT forum)
    Poof, you'll be logging like a pro in seconds.
    Protip: Use long enough wires that you can place your hpt box where ever you want. Then hide the wires and green thing when you aren't scanning. I have mine tucked under the carpet in the center under the dash.
  16. #16 Re: Wideband question
    Feb 2009
    flintnasty MI
    IDK where everyone is getting this "hot exhaust" idea at... Every wideband out there will suggest installiation 3-6feet behind the motor.
    AEM instructions are probably a bit smaller than most... but meh.
    Mount the O2 sensor in the
    exhaust system at least 18 inches downstream from the exhaust port. If you anticipate
    high EGT's (over 800C), run a turbocharger, run at high RPM for extended periods of
    Page 8
    time or plan on running leaded race fuel then you must mount the sensor at least 36
    inches or more downstream of the exhaust port as all of these can cause the sensor to
    overheat.
  17. #17 Re: Wideband question
    Ohio
    I always ran mine at the adapter piece of the sd headers where their bung is. Worked fine for me.
  18. #18 Re: Wideband question
    May 2008
    Schuyler, NE
    I have a wideband in the front postition at the header collector, and another in the rear where the second O2 goes. They read within .1 AFR of eachother.
  19. #19 Re: Wideband question
    Oct 2011
    MI
    You dont have any factory narrows?
  20. #20 Re: Wideband question
    I have mine in the rear 02 spot with no cat with no problems. Only time its a little off is cruise and idle type rpms (where ALL widebands are less accurate) but thats where the narrowbands do the work (assuming youre using them). When going wot, that spot will be plenty hot for accurate readings...
  1. Wideband Question
    By Freddy in forum General Tech Discussion
    Last Post: 11-27-2012, 11:29 PM
  2. AEM wideband question?
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-08-2012, 03:26 PM
  3. wideband O2 placement question?
    By buickman104 in forum PCM Tuning
    Last Post: 05-10-2012, 09:41 PM
  4. Wideband Gauge Question
    By Bedwards in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2010, 04:31 PM
