Thread: HPTuners bin files
Results 1 to 4 of 4
  1. #1 HPTuners bin files
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I've got hptuners pro and have been modifying my pcm.. Mainly the trans but I don't know much about the engine settings anyone have any good files for a CompG from someone who knows what they are doing?
    I've already changed some fan settings but not much else.
    Mods are in sig. Im going to drop a pulley size to 3.6 here shortly.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  2. #2 Re: HPTuners bin files
    You are suppose to make changes based off of what the car is telling you.
    So if you go out and log some WOT runs, you'll want to look for things in the those runs that could be changed.
    Watch fuel trims and KR and so on. Look at where they happen etc etc.
    Be it that you are still on a stock pulley and just headers, not much is needed to be changed. Fueling is still going to more than enough and timing aswell. Perhaps a MAF tune can help smooth things out and help with fuel trims if you need it.
    There are those few threads on here that give you basics on how to do some tuning but I wouldn't follow them to a "T".
  3. #3 Re: HPTuners bin files
    Arizona
    Look in the sticky above hpt tuning 101 and read and then read again but a general rule ve -log-maf-log-fuel-log-spark-log keep logging rinse and repeat
  4. #4 Re: HPTuners bin files
    Oct 2011
    MI
    Thx I'll check it out.
  1. Stock cal files needed! (04 GT / GTP / CompG)
    By RivMan in forum PCM Tuning
    Last Post: 12-31-2012, 09:00 AM
  2. No way to upload any files
    By mgolin in forum Forum Bugs/Suggestions
    Last Post: 09-05-2011, 12:04 PM
  3. Bin files?
    By Pure2sin in forum PCM Tuning
    Last Post: 08-20-2011, 08:16 AM
  4. Hptuners
    By minichopper6hp in forum PCM Tuning
    Last Post: 06-07-2009, 01:26 PM
  5. Holley Performance Products Files Bankruptcy
    By archemedes in forum Off Topic Discussion
    Last Post: 02-14-2008, 07:26 PM
