Thread: hpt Scanner question
Results 1 to 13 of 13
  1. #1 hpt Scanner question
    SE Level Member GTPAIELLO's Avatar
    Aug 2012
    weymouth, ma
    hey guys whats up ? I have been trying to get my GTP to pass emissions in MASS. but it keeps throwing a P0401 EGR insuf flow , which in most cases leads to the MAP or the EGR tubes, I have addressed both and still throw this code , so I used the hpt scanner and unchecked this code in the settings to make sure the light doesnt come on again which it has not come back on , but now the problem is I can not get my PCM to complete a drive cycle , could this be because I deleted /unchecked this code? the only test that complete are the o2 heater and o2 sensor, the EGR,EVAP and CAT wont complete . I just dont understand , any help would be great , Thanks!
    2000 GTP - TURBO SETUP .
  2. #2 Re: hpt Scanner question????????????????????????????
    Feb 2008
    Not 100% positive, but I believe you have to set the code to not report. I think un-checking it just sets it to not cause the MIL to illuminate.
    Sent from my SkyRocket
  3. #3 Re: hpt Scanner question????????????????????????????
    Yup. And as for drive cycle. it takes a lot for all tests to run. Search for the drive cycle info I've posted.
  4. #4 Re: hpt Scanner question
    PS, edited your title so it didn't look like you were a hyper spazz without a shift key or grammar.
  5. #5 Re: hpt Scanner question
    Aug 2012
    weymouth, ma
    Thanks for the info guys , can i set that code not to report right from the hpt scanner ? I will also check out drive cycle test info as suggested (thanks Bill)
  6. #6 Re: hpt Scanner question
    Yeah.. you know that check box.. 2mm to the right is the dropdown. 1 mil on X, 2, mil on x, 3 No Report.
    You want #3
  7. #7 Re: hpt Scanner question
    Aug 2012
    weymouth, ma
    ok sweet i will check it out thanks again bill
  8. #8 Re: hpt Scanner question
    FWIW depending on your year, you could tell all the codes for the other stuff to er uh..not report and it'll clear the monitoring to be all set
    I learned that one when I was sick of trying to complete the drive cycle on mine. Had to pass that day.
  9. #9 Re: hpt Scanner question
    Nov 2011
    NY
    Hey Bill... Intersting! Care to provide just a bit more elaboration on that technique
  10. #10 Re: hpt Scanner question
    Arizona
    Once you buy hp tuners all you do is go to engine diag---dtc------look in the column to the right scroll down to find the code that you want to disable it will be set to either 1 or two...all you do is switch it to third option which is no report.
  11. #11 Re: hpt Scanner question
    Nov 2011
    NY
    tell all the codes for the other stuff to er uh..not report and it'll clear the monitoring to be all set - complete the drive cycle...
    So, if you set all the codes to no report it will clear the diagnostic and report drive cycle test's complete? That's what I'm asking?
  12. #12 Re: hpt Scanner question
    Arizona
    Quote Originally Posted by coolone View Post
    Yes
  13. #13 Re: hpt Scanner question
    Nov 2011
    NY
    Awesomeness!
  1. LED scanner question
    By iroc2 in forum General Tech Discussion
    Last Post: 11-14-2010, 12:42 AM
  2. has anyone used this scanner
    By gtp239 in forum General Tech Discussion
    Last Post: 09-25-2010, 10:47 AM
  3. ODB 2 Scanner.
    By Blueraven in forum General Tech Discussion
    Last Post: 11-24-2009, 10:43 AM
  4. OBD II Scanner's.
    By rynoman03 in forum General Tech Discussion
    Last Post: 08-31-2009, 01:20 PM
