Thread: Exhaust cutout causing KR and misfiring
Results 1 to 20 of 25
  1. #1 Exhaust cutout causing KR and misfiring
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    So I have a 07 GP turbo. I just installed an exhaust cutout and went for a drive with it open. When I get into the throttle, just like half throttle, I get a ridicules amount of KR and get misfires on pretty much all cylinders. On the last run I even tried I was at 56% throttle and I got a spike of 14.9 KR. Of course it was followed by lots of misfires, I would assume cuz I went to 0 degrees timing, sounded like I had an anti lag switch. Anyone have any idea what it could be? Oh and I do have hpt to tune with.
  2. #2 Re: Exhaust cutout causing KR and misfiring
    does it go back to normal with it shut?
    May 2012
    Fort Campbell, ky
    Yes it's normal with it shut. No KR and no misfires
  4. #4 Re: Exhaust cutout causing KR and misfiring
    Where did you install it at?
    May 2012
    Fort Campbell, ky
    On the lower down pipe just before where the cat back exhaust connects.
    May 2012
    Fort Campbell, ky
    It's a catless downpipe so it's where the cat would be
    May 2012
    Fort Campbell, ky
    Anybody have any idea what it could be or what I can do? I know I can just leave it closed but I want to be able to run it at the track in the spring
  8. #8 Re: Exhaust cutout causing KR and misfiring
    Feb 2009
    flintnasty MI
    you can still make full boost on half throttle... And when the cutout is open you will make more boost faster.
    What is your AFR before it starts missing? Commanded and actual please.
  9. #9 Re: Exhaust cutout causing KR and misfiring
    May 2012
    Fort Campbell, ky
    I was making full boost a lot quicker, I could really feel the difference even at half throttle. Commanded for closed loop is 14.7 and for open loop it stays between 11.7 and 12.1. When i drove it with the cutout open my AFR was all over the place and really lean. When I did get into the throttle I just noticed my injector duty was at 110% where on all my previous scans it would be around 70 and 80 at the same throttle and gear. My LTFT's and STFT's were also jumping around really bad which it never does. just before I started seeing KR my AFR was at 13.2 and i was at 56% throttle. I'm still kinda new to tuning thats why I want to get opintions before I start doing anything but I was hoping to get things worked out this weekend. I just don't understand how the cutout is effecting everything so much.
  10. #10 Re: Exhaust cutout causing KR and misfiring
    Quote Originally Posted by Wsmccoy View Post
    this entire post is exactly what's happening.
  11. #11 Re: Exhaust cutout causing KR and misfiring
    Texas
    I thought this was rather odd myself as it wouldn't seem it would ping just by having a cutout. Sal actually had a similar problem I believe he actually ended up running faster IIRC by closing the cutout. Unfortunately, he doesn't get on here often but does frequent clubgp. I would recommend sending him a pm. His name is Silver2K1 or something similar, he has a silver GP in his sig doing a burnout. Makes me want to close my cutout and scan to see if i notice a difference. Weather permitting ill do that this weekend.
    85 Corvette
    01 TA
    03 Z06
    May 2012
    Fort Campbell, ky
    Well I could feel it was a lot quicker before I saw KR. I'm wondering if the cutout is coming in contact with something maybe the swaybar and creating false knock because its not steady knock. It will go from nothing and spike up to crazy KR. So I'm going to crawl under the car and see today
    May 2012
    Fort Campbell, ky
    I understand that. I just don't get why everything changed so much just by using the cutout.
  14. #14 Re: Exhaust cutout causing KR and misfiring
    way, way more open exhaust. that makes a huge difference.
    May 2012
    Fort Campbell, ky
    So should I just redo my tune with the cutout open and have two tunes? One for open and one for closed
  16. #16 Re: Exhaust cutout causing KR and misfiring
  17. #17 Re: Exhaust cutout causing KR and misfiring
    May 2008
    Schuyler, NE
    Where do you have your O2 sensor at?
    May 2012
    Fort Campbell, ky
    Ok that's what I figured. Just wanted some opinions about it
    May 2012
    Fort Campbell, ky
    My O2 sensor is in the upper downpipe coming off the turbo. It's a Z3 downpipe
  20. #20 Re: Exhaust cutout causing KR and misfiring
    May 2008
    Schuyler, NE
    Ah, ok. Maybe I missed it...what is your fueling setup?
  1. Is this a manual exhaust cutout?
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 10-04-2011, 06:52 PM
  2. Exhaust Cutout on a GTP? Lose torque?
    By GrandPrixGTP1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2011, 08:27 AM
  3. Electronic exhaust cutout
    By gptrell502 in forum Visual/Body Modifications
    Last Post: 10-28-2009, 11:18 PM
  4. Ideal exhaust cutout loc.?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-03-2008, 02:40 PM
