Thread: Intense HELP
Results 1 to 3 of 3
  1. #1 Intense HELP
    NY
    Not to sure what to pick Can someone help me? The only mods i have are cai down pipe will be gettting hv3 soon
    Please select your PCM level:
    Standard PCM ($124.99, plus selected a la carte upgrades below)
    Custom PCM ($174.99 for unlimited upgrades, please do not select a la carte upgrades, instead enter your information into the "custom settings" box)
    PCM Tune-Up ($49.99 for unlimited upgrades to an INTENSE PCM Tune, please do not select a la carte upgrades, instead enter your information into the "custom settings" box)
    Please select your idle speed:
    Stock idle speed tables
    Increase idle speed tables by 100 RPM (+$20.00)
    Please select your cooling fan engagement settings:
    Adjust cooling fan settings to correspond with 160 degree thermostat (+$20.00)
    Adjust cooling fan settings to correspond with 180 degree thermostat
    Adjust cooling fan settings to correspond with 195 degree (stock) thermostat (+$20.00)
    Please select your timing tables:
    Stock WOT ignition timing tables - ideal for supercharged vehicles where 91 or 92 octane fuel is the highest available
    Increase WOT ignition timing tables by up to 1 degree - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (+$20.00)
    Increase WOT ignition timing tables by up to 2 degrees - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (+$20.00)
    Increase WOT ignition timing tables by up to 3 degrees - ideal for naturally aspirated vehicles with any premium fuel, or supercharged vehicles with stock camshaft where 93 or 94 octane fuel is readily available (+$20.00)
    Increase WOT ignition timing tables by up to 4 degrees - ideal for supercharged vehicles with aftermarket camshaft or intercooler where 93 or 94 octane fuel is readily available (+$20.00)
    Stock WOT ignition timing tables with adjustable timing control - ideal for vehicles equipped with a Casper's Timing Commander, Happy Knob or ICCU - we will contact you for timing table information (+$20.00)
    Please select your disabled DTC settings:
    Disable random/multiple misfire DTC's (ideal for vehicles with aftermarket camshaft) (+$20.00)
    Disable rear O2 sensor DTC's (+$20.00)
    Disable EGR DTC's (+$20.00)
    Disable EVAP DTC's (+$20.00)
    Please select your transaxle shift settings:
    Leave WOT shift points at stock settings - ideal for vehicles with stock rocker arms and camshaft (+$20.00)
    Increase WOT shift points to approximately 6,000 RPM and engine rev limiters to 6,200 RPM - ideal for vehicles with higher ratio rocker arms and stock camshaft
    Increase WOT shift points to approximately 6,250 RPM and engine rev limiters to 6,500 RPM - ideal for vehicles with mild camshaft, such as the INTENSE Stage 1X grinds (+$20.00)
    Increase WOT shift points to approximately 6,500 RPM and engine rev limiters to 6,750 RPM - ideal for vehicles with medium camshaft, such as the INTENSE Stage 2 grinds (+$20.00)
    Increase WOT shift points to approximately 6,750 RPM and engine rev limiters to 7,000 RPM - ideal for vehicles with aggressive camshaft, such as the INTENSE Stage 3 grinds (+$20.00)
  2. #2 Re: Intense HELP
    I wouldnt even bother with those mods.
  3. #3 Re: Intense HELP
    Only thing you'd benefit from is the fan settings and honestly.. that's not going to do anything for you unless it's summertime or you do a lot of city driving.
  1. intense pcm?
    By shawn3091 in forum Off Topic Discussion
    Last Post: 01-02-2010, 06:11 PM
  2. Looking to buy a Intense PCM
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-02-2009, 09:59 AM
  3. Intense MPS vs. ZZP MPS
    By 04CompG in forum General Tech Discussion
    Last Post: 10-07-2008, 05:03 PM
