Thread: How do I know what OSID (OS ID) should be in my pcm
Results 1 to 11 of 11
  1. #1 How do I know what OSID (OS ID) should be in my pcm
    Follow this site and type in your vin.
    TIS
    It should tell you what your car was shipped with, any updates to the OS along the way and the most current that your vehicle could have if it has been updated/flashed recently.
  2. #2 Re: How do I know what OSID (OS ID) should be in my pcm
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Any way I can use this to find out what bin to flash my 2001 gt (top swapped) with a gtp bin? Also wont hp-tuners licensing freak out about flashing different osids and whatnot?
    Ohio
    Just use a gtp pcm and change the gear ratio... That's all really.
  4. #4 Re: How do I know what OSID (OS ID) should be in my pcm
    You can't use a manufacturer website to know how to modify a vehicle they tell you not to modify. Follow Mike's advice if you don't have emissions to worry about.
  5. #5 Re: How do I know what OSID (OS ID) should be in my pcm
    Apr 2011
    South Dakota
    So ill just flash a gtp bin from 2001 and transfer over my injectors and maf tables and whatnot. Any way to keep hptuners happy throughout the transition?
  6. #6 Re: How do I know what OSID (OS ID) should be in my pcm
    Uh..if you change a couple of tables and use an L67 bin to begin with, it should stay happy with you. The only catch that I've run into was trying to put an NA Vin on an SC bin. Reason being is HPT validates (or used to validate) the vin to the bin, meaning since no vin K car would ever have an oSID for a SC motor, it would complain. And after saying that, I'll tell you that I flashed my Regal GS (Vin 1) car with a Vin K OSID and changed the Vin successfully to the correct SC car vin.
  7. #7 Re: How do I know what OSID (OS ID) should be in my pcm
    Apr 2011
    South Dakota
    What happens if I began with a l36 bin thats already licensed?
  8. #8 Re: How do I know what OSID (OS ID) should be in my pcm
    The boost control soleniod would not be mapped out in the software. I think that and the pump speed relay (which you don't have in an L36 car anyhow) are the only things that are truly different. I find it easier to use the L67 to start instead of trying to change every table and worry about tables that you don't have access to.
  9. #9 Re: How do I know what OSID (OS ID) should be in my pcm
    Apr 2011
    South Dakota
    i was refering to licensing wise but as far as i can tell ill be shelling out for more credits unless theres a way to upgrade from my single vehicle license to a entire model year license. Howd you manage to flash a non matching vin? If i dont have the right vin in there wont my bcm and whatnot freak out?
  10. #10 Re: How do I know what OSID (OS ID) should be in my pcm
    Your BCM should want the right year...model shouldn't be as much of an issue. Don't quote me on that. My bcm is a happy clam.
    How did I do it... dude if I knew, I'd tell you. I'm using the latest beta version of the software and it just worked. As for upgrading from single to full year..it'll cost you 3 credits.
  11. #11 Re: How do I know what OSID (OS ID) should be in my pcm
    Apr 2011
    South Dakota
    For some reason reading you refer to your bcm as "happy as a clam" made me laugh out loud. I'll just do the model year upgrade and give it a try. I'll tell you how it goes with the Vin because I'm also running the latest 2.3 beta
  1. adding support for diff OSID in DHP or Tinytuner? How
    By Z34Phoenix in forum PCM Tuning
    Last Post: 12-30-2011, 09:02 PM
  2. Need .bin with OSID 12211476
    By Bedwards in forum PCM Tuning
    Last Post: 07-28-2011, 11:05 PM
