Thread: HP tuner, tuning classes?
Results 1 to 8 of 8
  1. #1 HP tuner, tuning classes?
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    hey i was just curious if anyone knew if there was any tuning classes either offerd by hp tuners or any other places that are l67 specific or atleast give me a good idea with it all, or if it is just kind of a learn as you go type of thing. Im completley new to the whole tuning thing and im wanting to buy hp tuners insanely soon so im just trying to figure out what all my options are to learn it. I would like to be able to broden my options down the road with learning cobalts and LS engines too since i know lots of people with both but i need to get started and learn ALOT before i even attempt all that noise. any help is appreciated and like i said im a total newb to the tuning so all help and info is appreciated
  2. #2 Re: HP tuner, tuning classes?
    Grand Island, Nebraska
    Once you get it go onto the HPTuners forum and read. Itll take some time to learn everything but its not impossible.
  3. #3 Re: HP tuner, tuning classes?
    May 2012
    Iowa
    ok so which one of the hp tuner set up's would i want to buy? and also do they hook up to the fords or the dodges if you buy the credits or do you need a diff hp program for them? and pretty much what i need to do is just buy hp tuners go to the forum and learn from there? i just read the how to write up from the other nick and it doesnt seem to bad but im sure theres alot more to it once u start diggin around more
  4. #4 Re: HP tuner, tuning classes?
    Topeka, KS
    The Pro if you wanna use wideband and not tap into the EGR port and make it work for wideband.
  5. #5 Re: HP tuner, tuning classes?
    May 2012
    Iowa
    Is that the only difference? And how does the pro read the wideband then?
  6. #6 Re: HP tuner, tuning classes?
    Topeka, KS
    The Pro has Black Box Mode too. The pro reads the wideband through a port on the side of the control box. It has a 5v signal and ground you can hook it into.
    HPTuners.com >> Performance At Your Fingertips for more info.
  7. #7 Re: HP tuner, tuning classes?
    I hooked mine into the EGR, its a pain though.
  8. #8 Re: HP tuner, tuning classes?
    Just found this, i think im going to get it eventually. Might want to pick this up.
    Amazon.com: Engine Management: Advanced Tuning (9781932494426): Greg Banish: Books
  1. Replies: 50
    Last Post: 06-06-2012, 08:49 PM
  2. Replies: 1
    Last Post: 01-29-2011, 02:42 AM
  3. pcm tuning questions with hp tuner
    By e6600 in forum General Tech Discussion
    Last Post: 03-29-2010, 07:36 PM
  4. Networking Classes
    By SWARTZ11 in forum Off Topic Discussion
    Last Post: 06-27-2009, 04:07 AM
