Thread: Can I use a 98-03 Hopped up PCM in a 97 model
Results 1 to 16 of 16
  1. #1 Can I use a 98-03 Hopped up PCM in a 97 model
    North Mississippi
    I have a 97 gtp whose pcm has the KR built in. Once upon a time it was hopped up, then, sadlly, I took it into GM but forgot to tell them not to reflash it. Thus it is back to stock (what a difference).
    The 98 -03 models do not have that anti KR thing.
    I have a DHP as well as an Overkill PCM which I believe came off of 98 models that I've acquired over the years.
    Has anyone tried to use a hopped up PCM in a 97 model and/or will it work?
    Thanks
  2. #2 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Yoga city
    97 for sure will not work in any other years.
  3. #3 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    North Mississippi
    Thanks for the input.
    Looks like unless I have access to a tuner, my other option will be to look for a 97 pcm that someone is ditching. I hate the thought of sending out for another pcm from any of the outfits that retune pcms.
    Kind of sucks to have a smaller pulley, TOG's, and the Borla exhaust on it and not optimally benefit from them.
    Looks like I will have to peddle a couple of pcms in the future or get a newer gtp
  4. #4 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Out West
    Quote Originally Posted by onemart View Post
    Thanks
    What does this even mean?
    Whine with your Cheese?
  5. #5 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Nixon View Post
    IDK
    Looks like he needs to kick around here a little and do some research.
  6. #6 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Florida
    didnt the 97GTP have a 4t60e? i think i remember hearing that....
    the later gtp's have a 4t65eHD so no your 98 pcms wont work.
    if you were closer i would be able to use my off board to scan your 98+ pcms for you and adapt it to your 97 pcm. and throw in custom tuning. your best bet is to ask around and see if there is anyone local who has a tuner and will tune your car.
  7. #7 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Mar 2012
    NC
    97+ GTP were all 4T65e-HD's...the 97 GT had the 4T60e
  8. #8 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Howell, NJ
    What's this about 97 pcms having an "anti KR thing" built in.
  9. #9 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Out West
    They don't.
  10. #10 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Texas
    How much are you willing to pay for a 97 PCM? I have one in my garage that is an Intense one.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Not sure what it is called, the the '97's do have a sensor of some sort built into the PCM that has to be kept with the vehicle (at least I thought)...
  12. #12 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Texas
    ^ yes I believe that's correct. I vaguely remember swapping over my module when I replaced mine.
    85 Corvette
    01 TA
    03 Z06
  13. #13 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    I live here. TLSheff's Avatar
    The E-Prom chip?
  14. #14 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    North Mississippi
    Thanks to bluegtp91 for posting a picture of the '97 pcm.
    It is my understanding that whatever that additional sensor happens to be, it, as you noted is for a '97 model. The two pcm's I have do not have that sensor as they are both pulled from '98 models according to the sellers, thus my query.
    From what I can tell, while there is plenty of compatibility and interchangeability of plenty of items on the 97-03 models, however, in the case of the '97 pcm, this is one area that lacks compatibility.
    My goal was to be sure about it, and the postings confirm my suspicion.
    Appreciate the help.
  15. #15 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Don't feel bad... 97 was a bastard year for alot of cars... The Camaro/TA had issues with the PCMS in 97 as well, 99+ was when they got the bugs worked out for most of the "performance" line-up.
  16. #16 Re: Can I use a 98-03 Hopped up PCM in a 97 model
    Florida
    My 96 DOHC had that same opening and a removalbe chip under it. I never had to swap this when I went to a diff 96 PCM. So as long as you find another 97 you will be good. Like said you can get a vendor to burn you one or if someone is local thy can tune your current 97 PCM. What are you looking to spend? Maybe I can cut you a deal?
  1. Fast... Model A?
    By Explicit_Spade in forum Off Topic Discussion
    Last Post: 06-23-2011, 10:29 PM
  2. what model of gp's have the hud wires
    By Soviet in forum Off Topic Discussion
    Last Post: 11-03-2010, 09:49 AM
  3. Bug Shield on 97-03 Model
    By brandonl2000 in forum Off Topic Discussion
    Last Post: 07-10-2010, 12:14 PM
  4. GP 1969 Model j
    By Olivier in forum General Tech Discussion
    Last Post: 04-27-2010, 04:19 PM
  5. NEW GTP! (98 model)
    By dovercast in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 01:35 PM
