Thread: Need a Case relearn?
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    GTP Level Member apierce1289's Avatar
    United States
    Gm can rewrite though.
    A dealership scan tool could. But your generic obd2 scanner won't.
    Sent from my Droid Razr using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #22 Re: Need a Case relearn?
    Dec 2011
    Champaign, IL
    I just installed my ECM from Overkill and my check engine light is on, called my local GM Stealership, and they acted like they had no idea what a case re-learn was. I explained I have a tuned ECM in and they told me the only thing they would do is reset it to factory settings. They will not even mess with any aftermarket ECM and let the car leave the shop without the stock ECM settings.
    What the heck do I do now? Only GM dealership in the area - called them twice to re-explain but I get the same answer. Two local shops I've called don't have the tools to do a re-learn.
  3. #23 Re: Need a Case relearn?
    Nov 2012
    Madison
    Quote Originally Posted by rideus View Post
    buy a OBD-2 and Torque app and clear it
  4. #24 Re: Need a Case relearn?
    Why resurrect a thread that is over 6 months old just to hijack it? Take your car to Autozone or Oriellys and have them scan it for you and pull the codes.
  5. #25 Re: Need a Case relearn?
    Dec 2011
    Champaign, IL
    Quote Originally Posted by slick2500 View Post
    This was the "Newest" thread I found discussing case re-learns. All of the threads were old........then if I start a new one, someone tells me there is already a thread and I shouldn't have started a new one. My post was about case re-learns and from what I read, so is this thread.
  6. #26 Re: Need a Case relearn?
    Yeah there are tons of them, but resurrecting old threads and hijacking them is still usually frowned upon.
  1. EFILive Case Relearn?
    By klj5022 in forum General Tech Discussion
    Last Post: 02-26-2011, 03:24 PM
  2. Effects of Case Relearn
    Last Post: 02-25-2011, 08:47 AM
  3. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
  4. Security Relearn
    By 04CompG in forum General Tech Discussion
    Last Post: 09-12-2008, 05:25 PM
  5. IAC relearn ASAP?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-29-2008, 12:23 PM
