Thread: Vehicel speed signal to ecm.
Results 1 to 3 of 3
  1. #1 Vehicel speed signal to ecm.
    Jun 2012
    Grantville, Ga
    What does teh speed signal hae to do with the fuel tuning on a 98 Grand Prix ecm. I have not found any where tht states what its for. Is it really needed for a rwd swap?
  2. #2 Re: Vehicel speed signal to ecm.
    Feb 2009
    flintnasty MI
    it mostly effects idle and dfco. You can get some stalling conditions, but otherwise you dont need a VSS. I have put a VSS on all of the RWD swaps I have done to eliminate any potential problems, but it is as I said not required.
    If you are doing a manual trans RWD swap.. I would put effort into installing a VSS.
  3. #3 Re: Vehicel speed signal to ecm.
    Jun 2012
    Grantville, Ga
    I am working on installing it know. Thanks for the reply
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Amp signal
    By superdad in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2011, 10:04 PM
  3. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  4. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
