Thread: Normal tuning specs or set ups?
Results 1 to 9 of 9
  1. #1 Normal tuning specs or set ups?
    Mn
    Hi guys. I have an 04 gtp and I am going to finally get it tuned. Im going to dyno tune usa in south dakota to andy tune it for me and I know he will do a great job, but I just want to know if there are any standard things to have him do? Like bump trans pressure, what temp do most of you normally set the fans for. Just stuff like that that he may not be used to on these cars since he does the big hp cars most of the time. As always thanks for any and all info!
  2. #2 Re: Normal tuning specs or set ups?
    Out West
    don't touch the fans unless you do a tstat.
    you could bump trans pressure a tad.
    how modded are you?
    Whine with your Cheese?
  3. #3 Re: Normal tuning specs or set ups?
    Mn
    I did a compression bump to 9.5, cam, headers, 180 tstat, one step cooler plugs, 3/4'' phenolic spacer under the sc, smaller pulley, opened up the lower intake, 255 pump, water meth injection and will have 42.5 lb injectors in once the tuning starts. I was thinking about 210 for the fans to kick in
  4. #4 Re: Normal tuning specs or set ups?
    Yay crappy injectors.
  5. #5 Re: Normal tuning specs or set ups?
    Mn
    Why are those crappy injectors?
  6. #6 Re: Normal tuning specs or set ups?
    May 2008
    Winnipeg, MB
    "smaller pulley" is kinda vague
    2007 Pontiac Grand Prix
    Quote Originally Posted by 91z View Post
    Find calibration and flow specs and their tolerances.
    You'll want to run around 16* timing with an afr in the low 11's.
    Then find the smallest pulley you can run that without kr even after heatsoak.
    If your tstat is a 180 youll want fans around 185-195.
  8. #8 Re: Normal tuning specs or set ups?
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Have the 3rd-4th upshift speed moved up in the 12.5% or more throttle fields. Unless you like accelerating in 4th.
    Don't really need a lot of tweaks to the torque converter.
  9. #9 Re: Normal tuning specs or set ups?
    Mn
    It has a 3.4 pulley on it. Thanks for all the info guys! This is great! Keep it coming if you have anything else. I finally have my fuel pressure in check so Im ready for more power through tuning
  1. Cam specs?
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2017, 09:18 PM
  2. torque specs
    By shawn3091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 11:37 PM
  3. alignment specs.
    By stlmo_gtp in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2009, 02:40 PM
  4. need torque specs for...
    Last Post: 04-17-2008, 12:16 AM
