Thread: Top swapped
Results 1 to 6 of 6
  1. #1 Top swapped
    SE Level Member Dragon1972's Avatar
    Would anyone have a bin file for a 97 GT top swapped? Thank you in advance for reading and possibly helping.
    Master Certified Automobile Technician
    1997 GP GT-SC
  2. #2 Re: Top swapped
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Are you on the original 4t60-e trans? If so keep us posted on how the trans is holding up. I'm top-swapping my 97 in a few months.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: Top swapped
    Does not exist.
    Which PCM? Which trans?
    Which TB?
    Which injectors?
  4. #4 Re: Top swapped
    Mar 2012
    NC
    The only way to tune the car properly is with Tiny Tuner and DHP or HPT. It's a giant PITA and I don't suggest it. Although my 4T60 held up very well to being top swapped, utilizing the boost control solenoid was impossible without Tiny Tuner and DHP or HPT. I had neither of those when I top swapped my 97. You can't simply plug the 4T60 data into the L67 bin or the trans won't shift out of second gear. You can put the L67 data over the 97 GT data but you will have no control over the BCS.
  5. #5 Re: Top swapped
    Feb 2009
    flintnasty MI
    You dont need a boost control solenoid... It was never even used on the 97gtp anyway..
    Just tune it yourself, you just need to add in some extra PE and adjust for whatever injectors you have... Use a stock GTP bin as your guide.
    I never used the boost solenoid even with a gtp bin.
    Trac is just too slow to react in my experience. Was able to pull my foot out of it before trac did anything.
  1. My red l67 swapped SD GTX conversion
    By thunder71173 in forum Members Rides
    Last Post: 01-20-2012, 01:48 PM
  2. Swapped 05 L32 into an 04 L26 HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 04-20-2011, 07:32 PM
  3. For the ones with top swapped engines.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2010, 01:18 AM
  4. l32 swapped 98 bonnee
    By boostedcompg in forum General Tech Discussion
    Last Post: 04-01-2010, 08:35 PM
  5. L67 Swapped
    By 99LuminaLSC in forum Chevrolet Lumina
    Last Post: 12-15-2007, 08:57 AM
