Thread: Top Swap Tuning
Results 1 to 8 of 8
  1. #1 Top Swap Tuning
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I have a 1999 GT which I just top swapped, along with a VS cam, headers, and an intake. I haven't used my HP Tuners in a while and I forget where to start. I was told I should use an L67 bin and transfer over the GT transmission settings. Will a 1999 GTP bin work? Won't they have different OSIDs and VINs? I'm not sure what to do! Thanks guys.
  2. #2 Re: Top Swap Tuning
    Your going to want to use your stock bin and transfer the L67 tables over into it. And just leave your stock Transmission settings alone
  3. #3 Re: Top Swap Tuning
    Quote Originally Posted by PokerBlakeB View Post
    Okay. Thank you very much.
    You cant if you want to use the l67 MAP.
  5. #5 Re: Top Swap Tuning
    Feb 2009
    flintnasty MI
    Why would anyone want to? I havent planned on boosting 6psi while my maf sensor is broken any time in the 8 years I have owned L67 cars.
  6. #6 Re: Top Swap Tuning
    I'm just saying it makes it kind of difficult to use an L36/L26 MAP without the UIM from the same engine.
    Also under the impression this guy has an L67 MAP already.
  7. #7 Re: Top Swap Tuning
    So how do I load an L67 file? Won't it recognize a different OSID/VIN?
  8. #8 Re: Top Swap Tuning
    Get a 1999 GTP bin, then inset your VIN.
    OSID shouldnt make a difference.
    Heres an OSID list:
    http://www.bonnevillepro.com/forums/...p?f=187&t=8950
    My car is a 2002 GT L36.
    It currently has a 2002 GTP L67 OSID on it. No issues thus far.
  1. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. Top Swap Tuning
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 04:26 PM
  4. need a little tuning help
    By 98daytona500 in forum PCM Tuning
    Last Post: 12-04-2008, 07:45 AM
