Thread: Going from 42.5* injectors to 80*......change my tables?
Results 1 to 20 of 35
  1. #1 Going from 42.5* injectors to 80*......change my tables?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    My topic pretty much says it all, do my tables need to be changed with these injectors? I haven't done anything to require more injector, I installed them thinking I might go E85 in the future, but for right now I want to run them at the same percentage as my 42.5's were at.
    Thanks.
    For all your 3800 needs:
  2. #2 Re: Going from 42.5* injectors to 80*......change my tables?
    utah
    i dunno...but what did you do with your 42.5's
  3. #3 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    Sold them
  4. #4 Re: Going from 42.5* injectors to 80*......change my tables?
    You will have to change the numbers.
  5. #5 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    I haven't done any tuning in a while, could someone lead me in the right direction? What tables to I have to change, and what type of change do I need to make?
  6. #6 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    Oh, and I'm a newb with the HPT, FYI
  7. #7 Re: Going from 42.5* injectors to 80*......change my tables?
    Jersey
    Divide your old injector size by the new injector size to get the variance. For example: 36 / 42.5 = 0.847. So... your new IFR table shall be 84.7% of the old table (highlight all cells in the IFR table, right-click, select CUSTOM, click on PERCENT, enter 84.7, click ok, this is what i would have to do since i have a DHP.
    *taken from the tuning bible*
    16' wrx sti- stock
  8. #8 Re: Going from 42.5* injectors to 80*......change my tables?
    Quote Originally Posted by 99prixgt View Post
    Why?
    Why not just insert the correct data from the start?
    Jason, have a rewire?
    If so, the IFR is the same all across.
    Same with the offsets.
    You'll want to find good data on your injectors and use that.
    Also use the rated flow rate and the calc built into HPT to find out the flow of your injectors at 3.5 BAR.
  9. #9 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    Matt: Yes I have a re-wire
    And the rest of what you said I believe was in a different language....... LOL!!
    I wish they had a class I could take for this HPT! Maybe it's my old age, but it seems harder to use than the PT.
  10. #10 Re: Going from 42.5* injectors to 80*......change my tables?
    Jersey
    damn, i need hpt
    16' wrx sti- stock
  11. #11 Re: Going from 42.5* injectors to 80*......change my tables?
    Your injectors have a "flow rate" when run static.
    Thats the rated flow at 43.5 PSI or 3 BAR.
    our fuel system namely the FPR is setup so that the injector always sees an effective pressure of 58 PSI or 4 BAR.
    Since the injectors inject a fluid, they do not flow linearly and follow Berneroulli's principle. Bernoulli's principle - Wikipedia, the free encyclopedia
    Injectors respond mostly linearly after 2-4 ms. Before that, they respond slower than expected. The smaller the pulse width (the on time commanded by the PCM) the longer they take to flow the expected rate.
  12. #12 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    So, if I'm tracking.....by using the offsets from my 42.5 injectors, I'm running quite rich with the 80 injectors?
  13. #13 Re: Going from 42.5* injectors to 80*......change my tables?
    Well offsets only affect idle and low throttle situations.
    The first thing you need to look at is your injector flow rate table.
    Which injectors do you have specifically?
  14. #14 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    Siemens Deka 80# Injectors
  15. #15 Re: Going from 42.5* injectors to 80*......change my tables?
    Offset vs volt:
    4.1033433 4.1033433 4.1033433 4.1033433 4.1033433 4.1033433 3.3738600 2.6291792 1.9604862 1.6261397 1.3069908 1.1702127 0.9726443 0.8358662 0.7446808 0.5927051 0.6079027 0.5927051 0.5775076 0.5775076 0.5775076 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000 0.0000000
  16. #16 Re: Going from 42.5* injectors to 80*......change my tables?
    Building offset vs pulse width vs MAP table
  17. #17 Re: Going from 42.5* injectors to 80*......change my tables?
    Use this in each collum in that last table:
    0.5471124
    0.4711246
    0.3951368
    0.3039514
    0.2279635
    0.1671732
    0.0911854
    0.0759878
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    0.0000000
    That should give you a pretty accurate fuel model granted your fuel pressure always changes 1:1 with manifold pressure/vacuum.
    You'd need to check your fuel pressure to make sure it doesnt drop off and changes properly with manifold conditions.
  18. #18 Re: Going from 42.5* injectors to 80*......change my tables?
    Orange County, NY
    great, we shall see what happens! Thanks for the help matt
  19. #19 Re: Going from 42.5* injectors to 80*......change my tables?
    Well it seems I might have mucked that up.
    Some sources say we have a 3.5 BAR FPR, not 4 bar.
    GM service manual is inconclusive as it gives a range of 51-59 PSI.
    Try it out, see how it runs, if it runs lean, then you might need to lower those values to reflect this mistake.
    I guess the real mistake is not finding out your true fuel pressure without vacuum on the FPR.
  20. #20 Re: Going from 42.5* injectors to 80*......change my tables?
    Jason...how new is your HPT? The most recent software has all the good stuff that we never before had to truly tune in the injectors.
  1. 2 LQ4 MAF tables?
    By Pure2sin in forum PCM Tuning
    Last Post: 11-17-2011, 11:56 PM
  2. 97-98 maf tables diff than 99+?
    By dsmuts in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2011, 08:53 AM
  3. Order to tune tables in?
    By Bedwards in forum PCM Tuning
    Last Post: 11-17-2010, 11:05 PM
  4. 42.5# injector tables for DHP PT
    By Sabrewings in forum PCM Tuning
    Last Post: 08-18-2009, 04:44 PM
  5. LT1 Maf tables
    By FoSHO99 in forum General Tech Discussion
    Last Post: 04-21-2009, 01:11 PM
