Thread: Tuning Advice?
Results 1 to 19 of 19
  1. #1 Tuning Advice?
    Outer Space
    Just looking for advice and directions.
    Changes made to my box-tuned zzp pcm are as follows:
    Injector_Skew_Percent +2% for 1,3,5 for plog
    Injector_Flow_Rate 100kPa: from 205.84 (stock value) to 207.84
    Here is the Latest scan RACETRACK_9-2-2008_8_06_37_PM_ from lawngoose -- Scan Depot dot net if anyone cares.
    Thanks all
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: Tuning Advice?
    Outer Space
    thanx to who all helped me.
  3. #3 Re: Tuning Advice?
    Jul 2008
    Poteau Oklahoma
    http://www.grandprixforums.net/f65/o...-pcm-5771.html
    this is a thread that I asked a few questions in.
    also there is another.
    http://www.grandprixforums.net/f65/j...ified-401.html
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  4. #4 Re: Tuning Advice?
    Jul 2008
    Poteau Oklahoma
    sorry that nobody answered you. most of these guys/gals were in Branson this last week. most of them that answer these questions.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  5. #5 Re: Tuning Advice?
    Outer Space
    I appreciate it man, I made some changes with the help of some guys from one of the other forums, but I have been reading the tuner's notebook, and I am in the process of doing a MAF tune.
  6. #6 Re: Tuning Advice?
    GT Level Member TurboKent's Avatar
    Woodward, OK
    using hp tuners or powertuner?
  7. #7 Re: Tuning Advice?
    TDCRacing
    Guest
    If you have stock injectors use the stock injector table. Adjust your fuel by the MAF table. Or Ve table for some ( matter of opinion ) I use the MAF and always will. I STILL have a stock VE table.
    Where did you get your values from for your IFR? Stock IFR for the 100KPA cell should be 38.40.
    FWIW Im using stock skew numbers and im tuning without a wideband. I have heard of people doing this and i guess it can't really hurt anything.
    Also what mods do you have? Looks your running a little lean on your narrowband o2's being that there at 920's.But then again I dont see any or much KR so your probably ok.
    Nevermind I see your mods and am actually suprised your running the 02 numbers you are without any KR with the mods you have
  8. #8 Re: Tuning Advice?
    TDCRacing
    Guest
    If you have HPT and you want me to take a look at your .BIN File for you I will. Just lemme know. And if you need anything else just lemme know. What else have you (or zzp) done to the PCM?
  9. #9 Re: Tuning Advice?
    Outer Space
    I have a DHP Tuner I picked up off a friend. I am in the process of doing a MAF tune. (Probably round 6) trying to get my LTFT's inline.
    RACETRACK_9-23-2008_9_36_59_AM from lawngoose -- Scan Depot dot net
    Mods are in sig, but I added a DIY shiftkit..
  10. #10 Re: Tuning Advice?
    Outer Space
    so basically, i plan to catch it on fire... since GP's are known for that.
  11. #11 Re: Tuning Advice?
    TDCRacing
    Guest
    What ya mean? Did you get the maf tune done?
  12. #12 Re: Tuning Advice?
    Outer Space
    Well what i have noticed is that during the mornings when i run my scans, im still running lean on my LTFT's ... +7 max, however, last nite i scanned... and I was get LTFT's up to +11.
    With it being cooler at night, I think my PCM would be commanding more fuel not less. So im still MAF tuning atm....
  13. #13 Re: Tuning Advice?
    NE Ohio
    Main Page - OpenTuner Notebook
    that will answer almost all the tuning questions you could ever have.
    also, just putting it out there..i think skewing the front bank because of a powerlog is useless. the rear and front banks are equal stock, but the rear manifold flows MUCH better than the stock front. if you think about it, the powerlog almost balances it out..
  14. #14 Re: Tuning Advice?
    Outer Space
    I have read the tuner's notebook a million times, and I can say it is true.. the more you read the more you learn with hands-on knowledge.
    I think I am pretty much done with my MAF tune... My LTFT locked in at 0 today on the interstate, so i am pretty proud of that.
    Latest_new from lawngoose -- Scan Depot dot net
    However, my o2's are still lean according to my narrowband.
    I still have KR 2-3*, so it doesnt look like a pulley drop is any time soon.
    Any advice and or direction is appreciated.
  15. #15 Re: Tuning Advice?
    TDCRacing
    Guest
    Matt, I'm not seeing any KR on that scan you took. Is it PT or just at WOT. If your FT's werent locking in when the knock was occuring then that can cause it. Also TM can cause it...usually around 2-3 KR also. Maybe disable it then go for a ride and see if that fixes it. What are you at on your NB?
  16. #16 Re: Tuning Advice?
    Outer Space
    A tad bit of KR in Cells 3507-3508 ... and 5169-5185. By NB i meant my PCM readings, but I have been eyeballing an AEM wideband after i get some headers
    I will take a look at your suggestions... thanks for the direction!
  17. #17 Re: Tuning Advice?
    TDCRacing
    Guest
    No problem man, Yeah that just looks like flash KR...Well i wouldn't even call it that. Dont worry about 1 or less kr...for me it's 2 or less... you def wont hurt anything with the amount you have now. Take into consideration most stock cars have 2-7 degrees anyway...and they last 300,000 miles.
    Tune looks good...or scan i should say.... Do some WOT runs if you like and post back up.
    Explain what you mean by pcm readings? Really the only way you can tell if your running lean or rich is to go into PE or when your o2's lock in...Then look at the o2 readings...
    For your setup go for around 940's to 960's...what ever you can do without KR...maybe 950's and add some timing also....stock is around 960's FYI if you didnt already know
  18. #18 Re: Tuning Advice?
    Outer Space
    I looked under TM but didnt see anything that caught my eye, I have a DHP Tuner... But I notice I generally get KR right upon shift...
    Ill do a WOT run in the morning and see what it looks like. Thanks for all the help!!!!!
  19. #19 Re: Tuning Advice?
    Outer Space
    So, I bit the bullet and bought headers... I will be installing them soon and then rescan to see whats going on with my KR situation.
    Next stop. 3.4
  1. Mr Trannyman, I need your advice
    By t24moore in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2008, 01:36 AM
  2. need info/advice
    By Quicksilver_GP in forum Off Topic Discussion
    Last Post: 05-28-2008, 11:24 PM
  3. exhaust advice
    By Scott B in forum General Tech Discussion
    Last Post: 05-28-2008, 09:45 PM
  4. Trannyman...need your advice...
    By VerzGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 07:52 AM
  5. Need Advice on 97 GTP
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 03-02-2008, 12:46 AM
