Thread: heat changes tune
Results 1 to 6 of 6
  1. #1 heat changes tune
    Been tweeking some stuff and have noticed my car runs perfect with the heat off but if I turn it on it runs like 2.0 richer? This ever happen to anyone else?
  2. #2 Re: heat changes tune
    Troy OH
    that's weird...
    you don't think your thermostat's a little stuck and the heat is dropping the coolant temp enough to make the pcm go to open loop do you?
  3. #3 Re: heat changes tune
    Portland Oregon
    Does it stay that way? When the AC compressor kicks on it adds load to the engine, that could cause it
  4. #4 Re: heat changes tune
    Quote Originally Posted by Poil336 View Post
    that's weird...
    I tune/run in open loop so I dont think its a temp thing
    Quote Originally Posted by OH4CompG View Post
    it stayed this way for the entire 10 min drive home... the thing that bothers me is that it was literally a constant 2.0 richer all across my maf frequency even in WOT...
  5. #5 Re: heat changes tune
    Feb 2009
    flintnasty MI
    fuel pressure?
    There is basically nothing that can throw things off that much.. Your commanded afr is staying in the 15/16s right?
  6. #6 Re: heat changes tune
    command isn moving dark... Ill check out the pressure on the way home tonight...
  1. No heat!
    By goldcrown61 in forum General Tech Discussion
    Last Post: 12-11-2011, 02:03 AM
  2. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  3. Low heat
    By citydriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2010, 08:20 PM
  4. Heat???
    By newmarket23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 12:44 AM
  5. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
