Thread: can some one load a tune on a pcm for me
Results 1 to 11 of 11
  1. #1 can some one load a tune on a pcm for me
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ok so my car is a 2001 gtp and i have headers cai,104s, 180 tstat,ported blower and 3.5 if i send someone a pcm can you load a tune on it for me for this setup also have 42.5lb injectors but there not installed yet and the pcm i have is from my old 2001 gt please pm me
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  2. #2 Re: can some one load a tune on a pcm for me
    Omaha, NE
    e-mail Overkill: :: Overkill Motorsports ::
  3. #3 Re: can some one load a tune on a pcm for me
    ya i don't wanna spend 150 for a tune i can buy used pcm with a canned tune on ig for 75-100 but thanks anyways
    sold 97 GTP stock
  4. #4 Re: can some one load a tune on a pcm for me
    Omaha, NE
    Oh really?
    2 HPT credits which are required for any HPT tune on a Grand Prix are $100 ($50 each).
    A used tune would not be specifially built for your mods like Wills tunes are.
    And with a used canned tuned pcm, if the VIN of your vehicle does not match the the VIN on the PCM then it will go into theft/security mode - Car wont start. You can use the PCM, you would just need to copy your factory PCM data file and overwrite the current file on the other PCM. so you would need it tuned to your VIN anyway.
    In order to tune a PCM out of the car, a special harness has to be made, which range from $75-150.
  5. #5 Re: can some one load a tune on a pcm for me
    ah ic i was hopeing someone would have dhp and just charge like 50 bucks just need a pcm till the sumer then im ripping the motor apart and redoing it with cam and all that good stuff
    sold 97 GTP stock
  6. #6 Re: can some one load a tune on a pcm for me
    Oh really?
    What year did they start the theft/security mode? I used a used canned tune for my 98 gtp and it worked fine.
  7. #7 Re: can some one load a tune on a pcm for me
    im thinking it was 2001 cause ther are some pcm that are 98-00 and that would probably be why
    sold 97 GTP stock
  8. #8 Re: can some one load a tune on a pcm for me
    Florida
    ok just FYI i know we are trying to convince him into getting a real tune... but come on 75-100 for an off board cable? seriously? for the 96-03 pcm you just need the blue side of the pcm connector and about a foot of wire, a power supply and a switch to simulate the ignition switch. made mine from spare parts and spent $10 on the connector at the junk yard IIRC.
    i dont think the series 2 had to be vin specific... but it is easy to update the vin while flashing the bin anyway.
    I dont agree with canned tunes. from experience tuning people down here in florida, it seems no one can get a file right. ZZP was the worst i have seen, but i have seen some recently from Will as well and the people who had them still had high levels of KR for their mod level. Location is the key though. down here we are at or very close to sea level which increase pressure both on and off boost. Will's stuff is by far the best out there that i have seen. but again from seeing it all first hand... nothing beats a tune in person.
    nascartech, if you want something cheep myself and many others can throw a base 2001 GTP file in your spare PCM, update your vin, and raise fueling blindly. if you want something that will actually make an improvement in your car, go with Will. if you want to be sure the car is running 100% get a tune in person. actually your up in CA and so is will. his tunes should be flawless for you.
    when you think about it, your looking for something cheap... lets say you pay me $50 to tune your PCM... you then need to pay shipping both ways... your better off just spending a little more and get a great product from IMO (and many others) the best in the business.
  9. #9 Re: can some one load a tune on a pcm for me
    Topeka, KS
    PM Reptile and see what he can do for you. He's done all the tuning on my car thus far and I haven't had any complaints.
  10. #10 Re: can some one load a tune on a pcm for me
    Banned
    CT
    I could hook you up with whatever you need. Tuning isn't some sort of magical procedure where you need a P.H.D to figure it out. It's common sense and after having tuned about 100 of these cars you know what settings work and what settings don't.
  11. #11 Re: can some one load a tune on a pcm for me
    ok thanks guys i just bought a ls1m so i can scan my car for kr and all that and see what it is doing so i can get a better tune before i send my pcm out
    sold 97 GTP stock
  1. Bogs under load
    By inition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:53 PM
  2. gtp missing under load
    By jshuman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2010, 01:12 AM
  3. Stalls under load.
    By reem82 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2009, 11:52 PM
  4. No power under load
    By workingpoor in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2009, 04:02 PM
  5. pinging only under load WHY ???
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-04-2008, 01:03 AM
