Thread: e85 cold start
Results 1 to 12 of 12
  1. #1 e85 cold start
    Chats
    7076
    With it cooling down it is getting difficult to start my car with e85 (which I new was gonna happen) you guys just adding some spark? Fuel? Both?
  2. #2 Re: e85 cold start
    Never Never Land
    Chats
    11961
    I think you'd need more spark. Adding more fuel is prob gonna drown the plugs and actually make it harder to start....but what do I know? I'm still researching this stuff lol.
  3. #3 Re: e85 cold start
    Jan 1970
    Maquoketa, Iowa
    Chats
    1302
    Standard should be switching to 04 timing tables when doing E85.
    That and if you get into tiny tuner start playing with crank or start up fueling.
  4. #4 Re: e85 cold start
    Chats
    7076
    I couldn't get tiny tuner going... Can't figure it out with HPtuners...
  5. #5 Re: e85 cold start
    Feb 2009
    flintnasty MI
    Chats
    3989
    i never really had to mess with it... never had problems as long as it was warmer than -10f out.
  6. #6 Re: e85 cold start
    Chats
    77762
    Brian is having issues with his car cold starting, Jarred.
    Might ask him if you haven't.
  7. #7 Re: e85 cold start
    Charles City, IA
    Chats
    3061
    Move up a heat range in plugs.
    SMGPFC Two Nipple General
  8. #8 Re: e85 cold start
    Chats
    7076
    Quote Originally Posted by TheOtherNick View Post
    I thought about that... did it make a difference for you?
  9. #9 Re: e85 cold start
    Bastard Reptile's Avatar
    Kansas City, MO
    Chats
    1492
    Not that I've had a chance to mess with it or anything lately.
  10. #10 Re: e85 cold start
    Dec 2011
    Wichita, Kansas
    Chats
    454
    maybe hotter plugs?
  11. #11 Re: e85 cold start
    GT Level Member jdmgtp's Avatar
    MI
    Chats
    hotter plugs might help. Adding fuel helps too. Couldn't get a quick startup under 50* no matter what I did with the tune. Didn't care much either.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  12. #12 Re: e85 cold start
    Feb 2009
    flintnasty MI
    Chats
    3989
    Tried starting my fiero last night in 15 degree weather...
    Turns out it was a bit rich and it really struggled.... although I do have 105# injectors. I would suggest making your really low coolant temp open loop AFR numbers quite a bit leaner.
  1. Cold start issue
    By Bedwards in forum PCM Tuning
    Last Post: 09-02-2011, 10:00 PM
  2. Hard Start When Cold
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 04-28-2011, 10:36 PM
  3. cold start smoke
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 09:42 PM
  4. Cold Start Injectors
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 01:20 AM
  5. Cold temp no start
    By mph68 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2008, 09:09 AM
