Thread: want to uupgrade to 3.4 but need tuning help
Results 1 to 20 of 40
  1. #1 want to uupgrade to 3.4 but need tuning help
    Ohio
    ive been reading for about a month now and im still lost in hptuners...
    car is a 97 gtp 75k on the odo
    speed daddy headers
    HAI
    Hptuners
    and i have a ported supercharger sitting with a 3.4 pully i want to install
    yet i donno if i should or if i should tune it for a 3.6 or somethign... if anyone here can help me tune id greatly appreciate it because im so lost
  2. #2 Re: want to uupgrade to 3.4 but need tuning help
    swift current,sask.
    Id get an mps setup and try the 3.6 out and see how much timing you can get out of it. You will get more power out of a setup with more timing and less boost. oh and read nicks tuning guide, It will help out lots. Do you have a wideband?
  3. #3 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    i have to do without a wideband right now because i have spent my budget.... that will be in the spring... and ive read that one and im still kinda lost.. i dont want to run the 3.4 and be lost on tuning then im going to be screwed... and then if the 3.4 is to much then im screwed because i cant go back up to stock without trying to get the mps hub off
  4. #4 Re: want to uupgrade to 3.4 but need tuning help
    new britain, ct
    you might as well go 3.4 because if you go 3.6 youd have to really tune it anyways. if you ever drop a pulley, you need to tune.
    07 Black GXP.
  5. #5 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    well i figured that... thats why i bought the tuner... i just need help... if i throw the supercharger on there with the pulley can someone help me tune it???
    the car is my DD so im kinda freaking out
  6. #6 Re: want to uupgrade to 3.4 but need tuning help
    Florida
    things to adjust for dropping pulleys is pull timing and add some fuel. if you want to be even more careful you can increase the attack rate for KR and increase the amt of timing KR would pull. keep in mind this is a starter file... its not like you will run this from then on... it is just so you have a safe starting point. if you have no issues on the first run then raise them back up/ then keep turning them back up till you see the first hint of KR and then back it down a little for safety.
  7. #7 Re: want to uupgrade to 3.4 but need tuning help
    West Side Michigan
    You could always get an MPS hub and purchase a 3.8, 3.4 and 3.6 pulley and see which you can make work. If you have trouble, swap the pulley back to the 3.8 until you get the hang of tuning.
  8. #8 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    Don't touch that pulley till you've mastered tuning it stock.
    I think you will appreciate that with the right tuning even a stock pullied car can go like stink.
    If you've leaned it out a whole bunch and still aren't seeing KR at 19* timing on a stock pulley, move on down to a 3.6.
  9. #9 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    ok well im completly lost in the tunning part... if i knew what everyone was talking about dropping i would do it but im freaking out lol
  10. #10 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    Do you get 19* of timing now?
  11. #11 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    are we talking at idle?? or wot...
  12. #12 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    WOT
  13. #13 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    i want to say its sitting at 14 or so but i havent touched anything on tunnning it yet... plus the IAT sits kinda high with the HAI but i will check a scan i have
  14. #14 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    I have HPT.
    Send some scans/latest tune on over my way.
  15. #15 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    ok well ill scan it for about 20 minutes tommarow and send it to you.. i must of deleted the one i had... thanks for the help
  16. #16 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    14 is like stock timing. What tune you running now?
  17. #17 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    im not running any tune... its just the stock file... i have no idea how to change anything lol
  18. #18 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    Get teamviewer and PM me if you're serious about getting yourself tuned. I'll give you some pointers.
  19. #19 Re: want to uupgrade to 3.4 but need tuning help
    Ohio
    ok that sounds awesome... ill get a good scan tommarow then send you a pm sometime tommarow... ill download team viewer right now... thanks alot..
  20. #20 Re: want to uupgrade to 3.4 but need tuning help
    Out West
    No problem.
    You really should look into a wideband though if you want to pulley down much further than a 3.6, Anything else is like firing bullets into a crowd.
  1. VE tuning....not necessary?
    By PacerSS in forum PCM Tuning
    Last Post: 09-21-2010, 08:06 PM
  2. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
  3. tuning help
    By iceman9669 in forum PCM Tuning
    Last Post: 01-29-2009, 12:35 AM
  4. what does tuning do to your car
    By triplecanopy in forum Off Topic Discussion
    Last Post: 12-23-2008, 11:33 AM
