Thread: Torque ltft don't seem right
Results 1 to 20 of 38
  1. #1 Torque ltft don't seem right
    I'm using torque and my ltft says 14.6 at idle and goes anywhere from 12-16 cruising. I think it's just torque but i could be wrong, wouldn't be the first time.
  2. #2 Re: Torque ltft don't seem right
    Omaha, NE
    Torque is a toy.
    Get an aeroforce.
  3. #3 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    Torque reads the same exact sensor and PCM data an aeroforce will.
    If Torque is reading 14's...guess what...that's because that is what the PCM is calculating for your LTFT.
    LOL @ Torque being a toy. cause you know...a 200 dollar gauge that can only display 1 or maybe 2 parameters at once with minimal (if any) logging capabilities is so much better.
    I paid 30 bucks for my adapter & torque combined. I can accurately log 6 parameters at once (more with a longer interval) including KR and tweet/facebook/export to CSV. I can email it on the fly or upload to a webserver.
    Lets see your fancy aeroforce do that...
    If you can't afford HPTuners...Torque is your next best bet. period.
    FWIW my LTFT are reading -10's or so on a ~15% blend of E85 at cruise. They lock somewhat close to 0 (-5 to +5) at full throttle but that's mostly a function of the leaner burn of the E85 causing the PCM to need to pull less fuel. It used to be upto -10 at 100% throttle
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  4. #4 Re: Torque ltft don't seem right
    What's the neg? Is the pos lean? I've not messed with this stuff to much.
  5. #5 Re: Torque ltft don't seem right
    Florida
    Neg means your fueling is rich and that the computer is pulling fuel. obviously if the trims are positive, then the pcm is adding fuel to compensate for a lean condition.
    if trims are +15% then in theory you can add 15% to your maf and be in balance. this is not always the case though... small steps. if i saw 15% i would do a 10% and test again.
    fubar569: one thing that may justify the aeroforce over an app for droid is the refresh rate. i bought a ScanGauge II as a replacement for my 1st gen aeroforce when the screen went out... big mistake. even at the highest refresh it cant even compare to the aeroforce's refresh. i could have KR and never see it! the gauge style scaners are great as an addition to a full data logger
  6. #6 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    Quote Originally Posted by Z34Phoenix View Post
    the refresh rate is limited by the adapter you buy as well. a high end adapter will refresh faster than an ebay cheapie but the ebay cheapie's resolution is fine for KR. I always see mine but then again i have a peak/hold gauge on my Torque dashboard specifically for KR. I have also limited the number of gauges, points im logging, as well as changed specific settings in torque to aid in data acquisition.
    FWIW our PCM's are also slow as hell. the peak PIDs read per second on my dad's 02 Deville is about 10 times that of my 99 Park Ave.
  7. #7 Re: Torque ltft don't seem right
    My torque tells me I'm running -30* of timing, 9* of KR and 5.5 psi of boost. I don't think its right. Because if that was right I am pretty sure my engine would have gone boom by now.
  8. #8 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    Quote Originally Posted by slick2500 View Post
    Either you're selecting the wrong PIDs or you're being sarcastic. either way can be fixed easily enough as problem exists between user and device.
    and nice to see your little buddy likes your post too. hi spade! LMK when you want to actually upgrade. i'd still be more than happy to help you out
  9. #9 Re: Torque ltft don't seem right
    Omaha, NE
    Why do you have to be rude and assume that its an error between the user and the device rather than an issue with the application?
    Let me know when you want to stop playing with toys.
  10. #10 Re: Torque ltft don't seem right
    Jun 2011
    Detroit, MI
    It would most likely be a problem with the chinese bluetooth crap
    iLoveSpade
  11. #11 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    because the application can only read what data you tell it to from the feed the hardware supplies it. period.
    hippo pretty much nailed it.
  12. #12 Re: Torque ltft don't seem right
    Omaha, NE
    Let me call you back, I'm datalogging.
  13. #13 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    looks like he's still bitter. that's fine.
    i got a good idea of what parameter you can try to monitor with your aeroforce next and exactly where you need to plug it in to do so.
  14. #14 Re: Torque ltft don't seem right
    Jun 2011
    Detroit, MI
    im half and half on this one, the app has good reviews from people that get it to work right, but android apps can be unstable, add that to the fact bluetooth adapters from china can have 0 quality control, and you can haz a mess
    iLoveSpade
  15. #15 Re: Torque ltft don't seem right
    Omaha, NE
    I'm not bitter, I'm just not ignorant.
    And go ahead and fill me in on this "parameter".
    Fubar, do you know what the LS1M is? If not it did more than your little cell phone game does, and it is no longer around. There's a reason certain things last and others don't.
  16. #16 Re: Torque ltft don't seem right
    West Side Michigan
  17. #17 Re: Torque ltft don't seem right
    Omaha, NE
    For factual comparison LS1M
    How fast does it scan?
    Testing on LS1 cars has shown a scan rate of 330-350mS for 10 parameters (30 parameters per second), down to 50-70mS for a single parameter (20 times a second). The fewer parameters you select, the faster the scan time is. During wide-open-throttle (WOT), the response time is about 20% slower because the car’s computer is busy and doesn’t respond as quickly to scan tool requests.
    I haven't found any information yet on the datarate of the Torque app or any bluetooth OBD2 transmitter, but I'll keep looking.
  18. #18 Re: Torque ltft don't seem right
    Omaha, NE
    Closest thing I've found so far, from Verizon
    What are the basic Bluetooth® data rate specs?
    Bluetooth has the capability to enable both voice and data (depending on the specific Bluetooth profiles included on the device). The voice channels typically operate at 64 kbit/s. The Bluetooth 1.0 data rates include an asymmetric data rate (one way) of 721 kbit/s (while permitting 57.6 kbit/s in the return direction); and a symmetric data rate of 432.6 kbit/s.
  19. #19 Re: Torque ltft don't seem right
    Jan 1970
    Maquoketa, Iowa
    97's.
  20. #20 Re: Torque ltft don't seem right
    Quote Originally Posted by FoSHO99 View Post
    97's.
    What?
  1. 16.4 LTFT at idle with E85
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2010, 03:24 PM
  2. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  3. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  4. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  5. Increased LTFT's?
    By jims05ss in forum General Tech Discussion
    Last Post: 12-17-2008, 07:49 PM
