I still have problem with cold starts. My car starts up and idles fine, but as soon as I throw it into gear (reverse or drive), the RPM and timing drops bad and it will stall. Sometimes it doesn't happen right after going into gear, but as soon as I touch the throttle, it gets no throttle response, and the RPM will drop. I have to press the throttle quite a bit to prevent it from stalling out, and the RPM will shoot back up. After about 1 minute of driving, the car is fine and never does it again. I have a scan of it dying this morning after putting it into reverse. Around frame 482 is where the problem begins.
Here is the HPT scan:
http://www.2shared.com/file/Ocb6y14v/Sept_9.html
Here is the spreadhseet format:
http://www.2shared.com/file/1aIDOTXz/Sept_9.html
