I know I can but do u need to change the vin in the tune before u can use it or will it just plug in an go..
^ What he said, and overkill has different tunes for different mod levels, so that could be an issue.
If you're buying a used PCM module, ensure that the mod list it's programmed for is similar to yours. As mentioned, you'll need a CompG version for your CompG as well. VIN doesn't matter.
For retune price ($50 plus $25 shipping), you can send the PCM in to update to my latest coding, retuned for your specific mods (no matter how long the list) and the corrected VIN.
New tunes are $149, not that expensive unless its a very good deal used and it matches your mod list. :: Overkill Motorsports ::
Will ill just order one from you instead of all the run around..
just ordered it hope it all goes well![]()
