Thread: pcm for 4t65e runing 4t65HD?
Results 1 to 9 of 9
  1. #1 pcm for 4t65e runing 4t65HD?
    Florida Tuner Z34Phoenix's Avatar
    Florida
    I know a PCM for a 4t65HD will run a 4t65e but will the opposite work?
    i want to know for sure if people have tried this, as i am considering a swap and the only file i can use was made for a 4t65e and never had an HD option. i know that people can rung a bin for a L67 and it run their non HD trany. but will say a L36 bin run a 4t65HD?
    and yes i know the gear ratio will be diff. i can adjust for that. i am currently running a gear swap from 3.43's to 3.73's in my 4t60e.
    96 Z34 (RIP LQ1 14.81@92.3) L36 Swap 14.9@91.5 www.cardomain.com/id/z34phoenix
    Topswap: P&P All,Si Valves,L76's,LW Pushrods,SD's,DHP PT PB 13.91@99.8
  2. #2 Re: pcm for 4t65e runing 4t65HD?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    if your talking grand prix the non-HD is 3.29 and HD is 2.93
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  3. #3 Re: pcm for 4t65e runing 4t65HD?
    Florida
    like said im not worried about the gear ratios... yes the normal non HD 4t65e is is a 3.29 some i read somewhere are even 3.05? and i know the HD's are 2.93.
    I am looking to run a 97 Z34 engine, PCM, and harness so that i can run a 4t65 on my DOHC engine. there was never an option for an HD trany with that engine...
    this is why i want to make sure a bin intended for a non HD trany will run a HD trany.
  4. #4 Re: pcm for 4t65e runing 4t65HD?
    Jan 1970
    Maquoketa, Iowa
    Just change the gear ratio... The only thing HD really does is a different size axle and a different Diff/housing. PCM doesn't care about that.
    If it helps, no mention of pcm reprogramming in this...
    ZZ Performance
  5. #5 Re: pcm for 4t65e runing 4t65HD?
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    you should only need a speed sen change
  6. #6 Re: pcm for 4t65e runing 4t65HD?
    Florida
    Ok
    For the gear swap I know the sprocket ratio needs changed. Shift tables obviously. Are u saying the actual speed sensor or the rev per mile in the bin?
  7. #7 Re: pcm for 4t65e runing 4t65HD?
    The only difference your pcm will see is the gear ratio. The only HD diffs are 3.29 ratio. Which when combined with the drive/drive sprockets are how you get to the 2.93 or 3.29 ratios.
    HD chainsets are always 1.21:1
    Non HD sets are always 1:1
  8. #8 Re: pcm for 4t65e runing 4t65HD?
    Florida
    so if i had a trany built for 3.69 gears it wouldnt have an HD diff?
  9. #9 Re: pcm for 4t65e runing 4t65HD?
    It could.
    See 4T65's are all basically the same. The differences are the drive/driven gearsets. The size of the diff HD or not (and ratio of planetaries/input sun gear) and the size of the output shaft.
    So if you choose to get a gearset to make a 3.69, you'll end up with a drive/driven ratio different from either of the stock ones available from the factory. Then addin the 3.29 HD diff or a 3.29 nonHD diff to give you a final result of 3.69's.
    It's the combo of drive/driven ratio plus diff ratio that will get you to 3.69. In this case, since HD and non-hd both have a 3.29 diff ratio available you could make a nonHD 3.69 trans.
    Don't let yourself get hung up on the HD ve non-HD wording. The only real difference is ratio at the drive/driven gears (input side) and the size of the differential.
  1. 4t65e-hd
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 04:46 PM
  2. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  3. 4T65HD Question...
    By WHT98GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2009, 07:21 AM
  4. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  5. 97 4t65e into a 99 gtp
    By BRIAN70SS in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-25-2009, 03:29 PM
