Thread: AFR for WOT on a stock GTP?
Results 1 to 7 of 7
  1. #1 AFR for WOT on a stock GTP?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Anyone know the AFR while WOT on a stock GTP? It must be extremely rich... Because after installing a VS cam, I started with a GTP MAF table and it's running 10.7. How can it be so rich with a cam? Seems crazy to me.
  2. #2 Re: AFR for WOT on a stock GTP?
    LTFT at WOT still 0?
    Also you're probably well outflowing a stock GTP so you're probably at parts of the MAF table that are normally never reached by a stock GTP.
    aim for 11.2-11.6
  3. #3 Re: AFR for WOT on a stock GTP?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    The stock AFR in a GTP begins in the mid 12's and starts dropping over time if I remember correctly. The VS cam or any cam for that matter requires that you tune your MAF table.
  4. #4 Re: AFR for WOT on a stock GTP?
    aim for 11.2-11.6
    LTFT is 0. I'm hitting 10.7 AFR from 7000 hz on. It's not a big deal, I can tune it. I was just curious.
    Quote Originally Posted by Juanmiguel View Post
    I know I have to tune it lol. I've been tuning for a while. I'm just confused why I had to pull fuel at WOT with the addition of a bigger cam. Thought that was odd.
  5. #5 Re: AFR for WOT on a stock GTP?
    Mexico
    I see, so you're talking about commanded AFR, or are you using a windeband?
  6. #6 Re: AFR for WOT on a stock GTP?
    I use a wideband. I did another scan this afternoon and noticed the AFR mid-11's, which is what I want. Maybe the 10.7 was outside air temperature related, not sure... It's hitting this AFR with ZERO tuning on a stock MAF table, from 7000 hz and up. I've obviously tuned my cruise settings, but my WOT fueling is fine as stock. Crazy.
  7. #7 Re: AFR for WOT on a stock GTP?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Bedwards View Post
    Not crazy.... I have been trying to tell people this for years.
  1. Stock stereo backlight inop? Which speakers to replace stock?
    By Z28 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2008, 11:47 PM
