Thread: Rich at idle
Results 1 to 7 of 7
  1. #1 Rich at idle
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    my car loads up on gas at idle and i read somewhere that there is a setting in hp tuners that controls the minimum pulse width, but i cant find it and my injectors wont go below 1.8ms
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: Rich at idle
    Bastard Reptile's Avatar
    Kansas City, MO
    It's been a while since I've had the non-beta version, but it's under engine/fuel/ flow rate vs. kpa
    What are your fuel trims looking like to be "loading up"?
  3. #3 Re: Rich at idle
    Jun 2010
    Beloit, WI
    all day yesterday anything below 1875 maf Hz would go straight to -16.4 but the rest of cruise was fine, and for the record i have 65# injectors.
    but on the other hand it seems like it has worked what ever was wrong out, because the ltft are now back within normal ranges today
    --00 Red GTP--
    13.07@108mph
  4. #4 Re: Rich at idle
    Kansas City, MO
    What does your idle on the wideband say though?
  5. #5 Re: Rich at idle
    Jun 2010
    Beloit, WI
    wideband reads normal right around 14.7
    --00 Red GTP--
    13.07@108mph
  6. #6 Re: Rich at idle
    Jun 2010
    Beloit, WI
    i take that back when after start wideband goes down to 10 which i dont thinks it reads below 10 and stays there for a period. Is there a table in ho tuners that adjusts startup fueling?
    --00 Red GTP--
    13.07@108mph
  7. #7 Re: Rich at idle
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by shawnschuldt View Post
    The car is supposed to run rich immediately after startup. It also has a decay table which brings it closer to stoich after a certain amount of time. I found when I messed with the startup AFR table, I had starting issues, especially when cold.
  1. rich idle, lean when high rpm and knock?
    By copperpacecar in forum General Tech Discussion
    Last Post: 07-30-2010, 03:24 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. running lean or rich + white smoke on idle
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 08:51 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. Car runs rich and surges at an idle?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2008, 02:54 PM
