Thread: gas mileage tune
Results 1 to 8 of 8
  1. #1 gas mileage tune
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    Im curious to see what some peoples spark maps look like for their gas mileage tunes.
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: gas mileage tune
    I've read up on lean-burn tuning...I don't tune but it is pretty interesting if you haven't checked it out yet.
  3. #3 Re: gas mileage tune
    Jun 2010
    Beloit, WI
    ill have to look it up thanks
    --00 Red GTP--
    13.07@108mph
  4. #4 Re: gas mileage tune
    optimum way to do something like this would be open loop tuning (the only way you can lean tune with our cars) and advance that timing as far as you can with no knock... you MUST have a wideband to do this though...
  5. #5 Re: gas mileage tune
    Feb 2009
    flintnasty MI
    Quote Originally Posted by gtpsleeper View Post
    You do not need a wideband...
    You can do a closed loop tune and keep an eye on the LTFTs... as long as you are not pegging out to +-10 you can go open loop and assume that you are well close enough to commanded AFR.
  6. #6 Re: gas mileage tune
    Jun 2010
    Beloit, WI
    its all good because i do have a wideband, thanks for the good info
    --00 Red GTP--
    13.07@108mph
  7. #7 Re: gas mileage tune
    You can't change stoich afr in closed loop....
  8. #8 Re: gas mileage tune
    GT Level Member jdmgtp's Avatar
    MI
    no dude he means mapping air flow for stoich in closed loop using the narrow band, then putting it in open loop and adjusting the commanded a/f ratio vs load and rpm.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  1. gas mileage
    By gpgt98 in forum General Grand Prix Discussion
    Last Post: 07-26-2018, 07:17 PM
  2. gas mileage ???
    By v8teezr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 07:13 PM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. Gas Mileage
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 11-28-2009, 11:57 PM
  5. Tune Up Advice, Just bought High Mileage Grand Prix GT
    By anicolay in forum General Tech Discussion
    Last Post: 04-29-2009, 02:57 PM
