Thread: Do I need a tuned PCM.
Results 1 to 20 of 42
  1. #1 Do I need a tuned PCM.
    May 2011
    Waterford Michigan
    Do I need a tuned PCM to run a 3.4 pulley on my 97 gtp with supporting mods?
  2. #2 Re: Do I need a tuned PCM.
    Charles City, IA
    yes
    SMGPFC Two Nipple General
  3. #3 Re: Do I need a tuned PCM.
    May 2011
    Waterford Michigan
    Do you recommend any cause I have a zzp PCM but keep hearing bad things about them so I haven't installed it.
  4. #4 Re: Do I need a tuned PCM.
    Charles City, IA
    custom tune or a dhp tune from 3800 performance
  5. #5 Re: Do I need a tuned PCM.
    May 2011
    Waterford Michigan
    Appreciate the help.
  6. #6 Re: Do I need a tuned PCM.
    May 2011
    Waterford Michigan
    What's dhp stand for exactly?
  7. #7 Re: Do I need a tuned PCM.
    GT Level Member jmoore4294's Avatar
    Digital Horsepower. Just the brand of the tuner they use.
    2004 Pontiac Grand Prix GT2 -Wizaired-DHP Tune-180° Thermostat-GMPP STB w/brackets F/R-Bilstein HD Struts w/SSC-Projector Retro-Black SPO Grilles and Spoiler-ZZP Volt. Booster & Alt Rewire
  8. #8 Re: Do I need a tuned PCM.
    May 2011
    Waterford Michigan
    Alright thank you.
  9. #9 Re: Do I need a tuned PCM.
    Feb 2009
    flintnasty MI
    Stock PCM works ok with a 3.4 pulley... all a tuned pcm is going to do is pull out power that the 3.4 pulley gives you that the motor cant handle.
  10. #10 Re: Do I need a tuned PCM.
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    which means it will blow quicker with a tuned pcm
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  11. #11 Re: Do I need a tuned PCM.
    Out West
    Custom Tuned is best.
    3.4 pulley just plain has diff fueling requirements than 3.8 pulley, not to mention MAF adjustments. Supporting mods or not.
  12. #12 Re: Do I need a tuned PCM.
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Nixon View Post
    Sort of right... The maf is fine, you never need to adjust that for pulley changes, but you typically have to throw 10.5:1 or richer at most 3.4 pulley setups to run them cleanly... While doing that you will be reducing your power back closer to where the 3.8 pulley left you.
  13. #13 Re: Do I need a tuned PCM.
    brunswick
    oo i see thankx what do i need to tune my stock pcm? or do i have to buy another one
  14. #14 Re: Do I need a tuned PCM.
    Out West
    A tuner interface such as HPTuners or DHP.
  15. #15 Re: Do I need a tuned PCM.
    brunswick
    okk thankx
  16. #16 Re: Do I need a tuned PCM.
    brunswick
    expensive?
  17. #17 Re: Do I need a tuned PCM.
    Kansas
    Looking at 500+ unless you come across one someone is selling. Then you potentially will need to buy credits.
  18. #18 Re: Do I need a tuned PCM.
    Quincy, Mass
    youll be safe with a 3.6 or 3.5 with a stock tune, start with the 3.6 to be safe and make sure you have no kr. try to find someone in your area with a tuner, experience is key to a proper tune. they will likely want some money for the tune but $100 is better than $500+
    No more GP 04 Impala SS Indy:
  19. #19 Re: Do I need a tuned PCM.
    brunswick
    Quote Originally Posted by Swiggles View Post
    their arent too many ppl around here that tune these cars better yet think they can go fast.... i've been looking since i got this car
  20. #20 Re: Do I need a tuned PCM.
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by GTPSHAWTY View Post
    Ive seen you on thechicagogarage right?
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  1. Tuned PCM.
    By GTP 40TH in forum General Tech Discussion
    Last Post: 06-16-2011, 06:07 AM
  2. Is my PCM tuned already?
    By KeithGTP03 in forum General Tech Discussion
    Last Post: 01-29-2011, 07:18 PM
  3. Help me with a Tuned PCM!
    By extreme in forum 04+ Specifics
    Last Post: 02-04-2010, 07:29 PM
  4. got the car tuned
    By QwikGT in forum Off Topic Discussion
    Last Post: 08-21-2008, 04:22 AM
