If you see KR on the chart display but it doesn't show up on the main spark- knock retard, timing retard (*) (2 of the histogram), does that mean its false knock?
The tune I'm looking over is Kaseys from the request in this section... He has a peak on the chart of about 1* KR, however his spark correction tables aren't zero'd. If I zero those do you think it would get rid of that KR or am I looking at it wrong?
maybe drop by -1 or +1 if kasey is clearly having a problem with "heatsoak" or hotlapping on a scan. but never 0 them out. they are there for a reason.
kick the scan on over to me and ill look it over.
Herp Derp...
I didn't have the histogram window open all the way... FML. I got it figured out now...
so i have a ? at full boost my kr is at 0, but idling it is -24 and when i first pulled out it went to -35 and just kept drop till full boost at 0, is this bad or good and what should i do about it
What are you using to scan? that sounds like ignition advance and 0 is terrible
my buddy that scanned it told me that it is ignition, it was negative 24 at idle, negative 35 when i pulled out then it kept goin down until i hit full boost and went to 0, we used a snap on scan tool, i want to measure the kr, how do i do that
