Thread: power enrichment timer
Results 1 to 7 of 7
  1. #1 power enrichment timer
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    i was wondering what would happen if i modified vertically instead of horizontally on this table because the longer i stay WOT the richer its show on my AEM wideband. or is there something else that i am missing? and i was also wondering how do i set up a custom PID for afr error i tryed all the thing that i have read on other posts but i dont think i am logging something on the primary table in hp scanner. suggestion, or advice greatly appreciated
  2. #2 Re: power enrichment timer
    Jan 1970
    Maquoketa, Iowa
    PE vs. Time just delete everything up to 14-16 seconds. That way it doesn't mess with your AFR during the 1/4 mile and if your playing around it's there to help some. If you're WOT for more time than that, you're not very smart, so let the pcm add some more fuel to save your ass.
  3. #3 Re: power enrichment timer
    springdale ar
    thanks ill give it a shot and see what happens. i dont usually got wot for more than 12-14 seconds so i should be pretty safe.
  4. #4 Re: power enrichment timer
  5. #5 Re: power enrichment timer
    Banned
    CT
    Quote Originally Posted by FoSHO99 View Post
    If you're going to delete the table up to 14-16 seconds make sure you adjust your PE AFR down to compensate... although if you do it this way, when you do hit the AFR/Time cells that start adding fuel, the AFR is going to plunge.
    Personally I don't touch this table as AFRs can be stabilized using other methods.
  6. #6 Re: power enrichment timer
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by SnowFlake View Post
    If you are trying to get your wideband afr's to match your commanded afr's the pe vs time table can mess this process up. By deleting this you are making the process easier. The point IS to let it richen up after 14 sec...?
    I don't know why you wouldn't want to keep things simple...
  7. #7 Re: power enrichment timer
    springdale ar
    is it normal to be in the positive on this table? i tryed to do a little WOT with narrow band and now that i have wideband ive taken a crap load of fuel out. normal or not?
    i took off 16+ and there was a slight change in the afr but it seems to be getting richer with time it does not stay the same for every 5 seconds and when i hit 2nd gear it get really rich it jumps from 11.3 to 10.6. should i find the correct value and change the whole table?
  1. Power enrichment / time necessary?
    By Juanmiguel in forum PCM Tuning
    Last Post: 05-14-2011, 03:30 PM
  2. just another 1st timer saying hi, from nc.
    By ak47 in forum Introductions/Noob Questions
    Last Post: 07-31-2010, 02:34 PM
  3. Yep, I'm a 1st timer!
    By telkel2399 in forum Introductions/Noob Questions
    Last Post: 12-05-2009, 07:06 PM
  4. Old Timer Newbie
    By GUTZGTP in forum Introductions/Noob Questions
    Last Post: 10-13-2009, 04:52 PM
  5. First Timer
    By kygtp in forum Introductions/Noob Questions
    Last Post: 10-22-2008, 10:27 AM
