Thread: Power enrichment / time necessary?
Results 1 to 6 of 6
Juanmiguel Power enrichment / time... 03-31-2011, 03:27 AM
01gpgt01 Re: Power enrichment / time... 04-01-2011, 08:31 AM
Juanmiguel Re: Power enrichment / time... 04-01-2011, 01:10 PM
Bio248 Re: Power enrichment / time... 04-01-2011, 01:13 PM
01gpgt01 Re: Power enrichment / time... 04-01-2011, 07:25 PM
jdmgtp Re: Power enrichment / time... 05-14-2011, 03:30 PM
  1. #1 Power enrichment / time necessary?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I took the GTP to the track today, just to find out that I didn't gain anything at all with my tune... lol.
    The only thing that bothers me is the PE_RPM_vs_TIME_A/F table. As you know, it modifies AFR over time. Which I don't know if it's entirely necessary I was trying to get around 11.2 AFR at WOT.
    Can I set this table to 0's and have the same AFR? Would it hurt?
    Here's a scan I took in the last pass. I have AFR set to 11.6 here, but the time A/F table made me run rich: (any thoughts about the scan - tune are also welcome. I already took care of the KR that showed up)
  2. #2 Re: Power enrichment / time necessary?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Mines Zeroed out untill 14.4 sec. I would not zero it out unless you are using a wideband. commanded AFR means dick. If thats your wideband AFR im seeing in your scan you have alot of PE tuning to do. You Ideally want to get your commanded AFR to match what your wideband says. Makes things easier. If you dont have a Wideband, You really need to invest in one.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Power enrichment / time necessary?
    Mexico
    I'm not using a wideband. I know the narrow band and the commanded AFR are not accurate, I was wondering what's the point of modifying the commanded AFR over time. Is it to somehow make up for the narrow band inaccuracy?
  4. #4 Re: Power enrichment / time necessary?
    more load on the engine means you need more fuel to quelch the oncoming detonation.
  5. #5 Re: Power enrichment / time necessary?
    Hagerstown,Md
    X2, But as you will find when you get a wideband it will be way off and you will just zero most of the table out and use it to add fuel where needed. I start the 1/4 mile at 12.1 afr finish with a 11.7 afr FWIW
  6. #6 Re: Power enrichment / time necessary?
    GT Level Member jdmgtp's Avatar
    MI
    I agree get a wideband on there. You shouldn't have any problems running 11.0-11.5 a/f ratio with full timing at those boost levels. I bet your quarter mile times were terrible.
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  3. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  4. Part time headlights, all the time
    By myzon26 in forum General Tech Discussion
    Last Post: 03-04-2010, 08:23 AM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
