Thread: cot air feul ratio
Results 1 to 8 of 8
  1. #1 cot air feul ratio
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    I'm running actress and I was wonder what do I do to disable cot. ThNks.
  2. #2 Re: cot air feul ratio
    I'm running catless and I was wondering what do I do to disable [whatever the hell you meant by COT]. Thanks.
  3. #3 Re: cot air feul ratio
    springdale ar
    Cat over temp for catless
  4. #4 Re: cot air feul ratio
    Omaha, NE
    Quote Originally Posted by xBlacKxGTPx View Post
    I'm running catless and I was wondering what I need to do to disable cat over temp? Thanks.
    Slow down when you post. The easier your posts are to understand the better we can assist you. That being said, I have no answer to your question.
  5. #5 Re: cot air feul ratio
    Florida
    was in jerrys note book years ago. not sure if it is in the version on the site or not. what tuner do you have? you might ask someone from the supporting web site for the codes to delete.
  6. #6 Re: cot air feul ratio
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Disable po420 by selecting number 3 in the drop down to Non report and unchecking SES enable
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: cot air feul ratio
    springdale ar
    i have a hp tuners std only sadly i still do not uderstand this completely i know it dumps fuel when it reads the cat is to hot, that being said if i run catless i have to raise this to a high temp to disable?
  8. #8 Re: cot air feul ratio
    Quincy, Mass
    correct
    No more GP 04 Impala SS Indy:
  1. Gear ratio's??
    By reallyfast1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-10-2010, 10:10 AM
  2. gear ratio
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2010, 02:01 PM
  3. 1.9 ratio rockers from ZZP
    By DBGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2010, 11:13 PM
  4. ZZP ER ratio rockers vs ZZP ST2 cam
    Last Post: 06-24-2010, 12:03 PM
  5. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
