Thread: PE nuts
Results 41 to 60 of 68
  1. #41 Re: PE nuts
    Barksdale AFB, LA
    Quote Originally Posted by Reptile View Post
    Just to clarify something. KR could be a few things...TM will show up as KR in the PCM and here's why. Anytime that timing is pulled it shows up as KR. yup, it's as simple as that.
    That's what I had heard.
    Now, onto the problem. I honestly think that this deal is running way to rich for a n/a. If you're running too much fuel, some can be left over in the cylinder, and once fresh air/fuel hits it it could be flubbing up your AFR and your timing. It probably is knocking from all the fuel it's getting.
    Okay, then why would it do the exact same thing with a full write of my 100% stock file? And the knock starts to go away the richer it gets. It seems that O2s in the 920-940 area have stopped it and the KR is recovering from then on. You can see that in the last scan I posted.
    Put the VE back to stock
    Put timing back to stock
    Fueling back to stock
    Raise all of your TM settings in your spark/fuel/transmissions tables...put them to the max.
    I did all that by the full write with my stock file. Well, except the TM part. Why would adding TM make this go away?
    I think we're on to something with the KR being spark reduction from a TM setting.
    2009 Subaru Impreza WRX STI
  2. #42 Re: PE nuts
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Your not increasing the TM just increasing the numbers under the TM tables wich if set to there max (higest numbers) will disable the TM. Brian was trying to say raise the numbers not the TM. makes sense? What this will do is prevent TM from being applied wich will prevent timing from being pulled wich will prevent the kr from happening,
    You have more mods than stock. So you would want to raise the TM setting even higher than stock because you will cross that threshold being you make more power than stock. Even with a stock setup TM is still being applied. Were just trying to exclude TM from possibly being the cause of your kr. Thats why were disabling it for now.
  3. #43 Re: PE nuts
    Bastard Reptile's Avatar
    Kansas City, MO
    ^Excactly. I should have mentioned by raising the TM numbers, the less it will try to pull timing. In this case More is Less type of deal applies. It just seems to me that the O2 numbers seem really high, but again I'm not versed in the N/A tuning. I know it's not going to take near as much fuel as a GTP, but maybe the O2's aren't what we need to be looking at...maybe it is your commanded AFR and your PEvsTime. A wideband would really help tuning out, but I know they're expensive to buy. I think the key is figuring out what the true AFR is versus what the actual AFR is.
    Sorry, I haven't looked at the scans, I'm on a work computer, and I'm limited to what I can see right now. I'll be more than happy to take a look at it when I get home.
    I might have a good .bin file that I could look at as well to see what's going on.
  4. #44 Re: PE nuts
    Barksdale AFB, LA
    I'm heading out of town tonight, and I'm going to try a bin file I prepped last night. I took away the torque management's ability to pull spark (I think). Gonna see what that does.
    As for the tables you're talking about, I know the two tables that say Max torque turbine locked and Max torque turbine unlocked. Both are filled with "1000" in each cell.
  5. #45 Re: PE nuts
    Barksdale AFB, LA
    There's no way this is TM. There must be something wrong with the car, be it bad gas, a bad O2 sensor, bad plugs. Something. She's sick.
    Look at this scan. It's so much worse today. I can hardly touch the throttle without knock now. I'll be lucky to be able to cruise on the highway with no knock.
    07022008_154958 from sabrewings -- Scan Depot dot net
  6. #46 Re: PE nuts
    Kansas City, MO
    knock at 6% throttle? no freaking way. that's literally impossible.
  7. #47 Re: PE nuts
    GTX Level Member webracin's Avatar
    Arkansas
    Got some more questions for you.....
    Do you have a aftermarket downpipe?
    Check out your front sway bar and make sure its not broken or hitting the downpipe.
    I know this sounds random, but if its something that may be hitting around the engine, it could trigger the knock sensor. You may have a bad knock sensor as well. I think you can pick them up fairly cheap (around 40 bucks) or you may want to get ahold of Ed Morad and see if he has a used one you can get really cheap just to try it out.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  8. #48 Re: PE nuts
    Barksdale AFB, LA
    Tell that to my car.
    I have some more supporting evidence to the "bad gas" theory. I just drove 380 miles home for my small vacation, and before I left I needed to top off. I put in about 4.5 gallons, which means I had about 12.5 gallons of suspected "bad gas". Throughout a lot of my trip, going up a hill it'd start knocking in the 10% TPS range. Halfway during the drive, it got better. I could lean in to the throttle and hold it at 20% TPS without knock. But, later on by the time I arrived (I'm now under a 1/4 tank) just cruising on open flat road at 75 MPH saw occasional random knock. I'm hoping that time that it was doing better was from the newer good gas (93) that I added mixing in and raising the overall octane of the bad gas. But, by the time I got here too much of it was gone... Eh, it's possible. Grasping for straws I guess.
    The way I knew it was knocking was my Aeroforce gauge. Didn't want to mess with the tuner during the drive. I set it to cyclic scan and the annunciator lights to go off at 1.5* of knock or more. Needless to say I saw a lot of red lights... When I left it on the knock value, I'd watch it jump straight to about 2-3*, begin recovery and actually make it to zero, then spike again. Sometimes it only spiked less than a degree and was instantly gone.
    I'm at a loss.
    Quote Originally Posted by webracin View Post
    Yes, a 2.5" from ZZP.
    I'll take a look tomorrow.
    I've suspected that and I've been hunting something loose. The "needle in a hay stack" analogy comes to mind...
    I've got a hookup with a guy at a GM dealer who gets me parts at cost pricing. I may get two new ones depending on how hard they are to change.
    I will definitely be replacing my O2 sensor while I'm here at home (I had my GM guy ship it here for me, it arrives tomorrow). With 67k miles it couldn't hurt. Next if 3800Performance shipped my order the day I placed it (though I got no shipment confirmation) then I'll soon have Poly motor mounts to install which maybe the reduced engine movement will help (assuming it's false knock).
    I wanted to do plugs and wires (plugs should arrive soon) but Paul at PRJ is out of town and I will have to wait on his wires until I get back to my base next week. So, plugs will wait until then, too.
    If these don't fix it, knock sensors I guess.
    I'm loving the ideas, though. Keep 'em coming. I really do hope it's false knock because the idea of my engine knocking that much makes me woozy.
    Gotta get to bed. I worked today and drove nearly six hours...
  9. #49 Re: PE nuts
    Kansas City, MO
    I really hope you find the problem, it's just weird. Knock sensors don't usually just go out, it's extremely uncommon. The front one is fairly easy to change....the rear...
  10. #50 Re: PE nuts
  11. #51 Re: PE nuts
    Barksdale AFB, LA
    I just filled up with a fresh tank and will see how it goes. In the mean time, could loose DP to manifold nuts or a ticking flex cause knock?
    Before I filled up today, I was able to get into the throttle fairly aggressively with little knock. It knocks the most when the TCC is locked and I push into the throttle. I'm not sure if the vibrations resonate in a certain way and cause something loose to rattle or what. The DP wasn't installed by me (had to take it to an exhaust shop and get the OEM DP cut out) so I can't be certain of their tightness.
  12. #52 Re: PE nuts
    TDCRacing
    Guest
    I wouldnt think that could cause knock...definetly not that much. no way. If it knocks when the tcc is locked it is either because of TM or because the engine is in a high gear and high load. wich could be normal. Shoot if i remember correctly i think the TM settings in dhp for the tcc locked are called something like ''Max torque TCC locked'' ''Max torque TCC unclocked' or something of that nature. Good luck and let us know
  13. #53 Re: PE nuts
    Barksdale AFB, LA
    I guess it is real knock then.
    Why doesn't it knock when I get into the throttle more and the TCC isn't locked? Like somewhat aggressive acceleration in 2nd gear around town...
  14. #54 Re: PE nuts
    TDCRacing
    Guest
    Well think about it like this. There is more of a load on the engine because of the tcc being locked and nothing beng allowed to slip. And that is why the knock is occuring while the tcc is locked vs. when it is unlocked. Plus like i said there is a TM table for it also. I guess if that doesent make since it's almost like being in forth gear going 30 and flooring it...lot's of excess fuel,big load on engine ect.
  15. #55 Re: PE nuts
    Barksdale AFB, LA
    Meant to say that I have those TCC tables filled to the max so they should never try to limit me. It's weird that I can get into the throttle and not see hardly any KR (nless I hit PE, that's still f'd up) but I can barely cruise without seeing 1.5-3*.
  16. #56 Re: PE nuts
    TDCRacing
    Guest
    Did ya get anything figured out yet man?
  17. #57 Re: PE nuts
    Barksdale AFB, LA
    Been on new gas for a couple days and no change. I'm also pretty sure it's real knock because when the engine is still pretty cool it won't do it. So, something is heating up in there and causing knock.
    I've got nearly 68k miles on the factory iridium plugs and I think they're causing knock. New plugs are on the way, and PRJ wires will meet me back home later this week. Tuesday I'm changing my O2 sensor.
    So, I'll see what happens. I've successfully eliminated gas as the issue, though I'd hate to see how bad it is with 87 instead of the 91/93 I have been using...
  18. #58 Re: PE nuts
    Barksdale AFB, LA
    No luck with changing plugs, O2 sensor, and wires. I'm now on AL605s, PRJ wires, and a brand new AC Delco O2 sensor and it's still the same, if not worse.
    I went WOT once and saw a solid 8* of KR with 880-890 O2s.
    Is the MAF used during WOT or when in PE? It might be suspect. I'm going to unplug it and see if the car acts any better...
  19. #59 Re: PE nuts
    Barksdale AFB, LA
    Also, would a leaking o-ring on an injector cause some knock? I smelled a little fuel while leaning over the alternator, and looking at the jetting on my #2 plug it may show some lean running. If I had a vacuum leak at the o-ring for that cylinder's injector, it may be explained.
  20. #60 Re: PE nuts
    TDCRacing
    Guest
    Yeah the maf is used all of the time. If you unplug it the pcm is going to resort to the VE table. How are you tuning your fuel? VE Table? Injectors table? MAF? Lets say you were tuning the fuel on your car by the maf. You got it running right. then you unplugged the maf. Well then the pcm is going to be looking at the VE table. Wich has stock fueling...get it? the VE table never changes unless you change it. It's been up in the air but some people claim that there car doesent even use the VE table with the MAF unplugged.
    Some people are able to zero out their VE table unplug the MAF and there car will run just fine. Me personally I dont tune the fuel with the VE table. I just use the MAF. And also some people say the only reason the ve table is even there is in the even you have a MAF falure, your car will still run. But if you dont tune via the VE table and you are highly modded and you happen to have a maf failure then your car may not run anyway lol.Some people also say that its better not to tune by the ve table and some say it is. just a matter of opinion i guess.
  1. rustang lug nuts question
    By nemesis in forum Tires & Wheels
    Last Post: 06-19-2008, 04:01 AM
  2. Where do these nuts belong?
    By DRWBRTq19 in forum General Tech Discussion
    Last Post: 06-16-2008, 11:22 PM
  3. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
