Thread: Removing O2 Sensor in Tune
Results 1 to 7 of 7
  1. #1 Removing O2 Sensor in Tune
    Aug 2016
    MN
    On a 99, is there any other changes I need to make to the tune in order to remove the rear O2 sensor besides disabling the dtc codes for it in the fault type and fault enabled fields?
    1998 Grand Prix GTP aka The Family Sedan
    CAI, 1.8 rockers, U-bend delete, 3.4 pulley, tuned by me
    1999 Turbo Grand Prix
    L36 turbo build in progress
  2. #2 Re: Removing O2 Sensor in Tune
    Nope, just disable the DTC and the COT (cat over temp) in the tune.
    HP Tuners has COT if I remember right.
  3. #3 Re: Removing O2 Sensor in Tune
    Aug 2016
    MN
    Thanks, What's cat over temp, is that another code? I have dhp
  4. #4 Re: Removing O2 Sensor in Tune
    Cat over temp is a table in the computer that when activated will richen the fuel mixture up to cool the cat converter down if the computer thinks it's too hot. It will try to save it from melting down.
    With the cat gone the table can be disabled to prevent the computer from adding fuel at random.
  5. #5 Re: Removing O2 Sensor in Tune
    in dhp you go to fuel, then base fueling, then you'll see the cat temp. change it to 248.
  6. #6 Re: Removing O2 Sensor in Tune
    Aug 2016
    MN
    Got it done, Thanks!
  7. #7 Re: Removing O2 Sensor in Tune
    you got it.
  1. Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    By Sinister Performance in forum PCM Tuning
    Last Post: 10-27-2017, 12:55 PM
  2. Socket/Wrench size for removing knock sensor
    By K Kraziee in forum General Tech Discussion
    Last Post: 05-30-2014, 04:43 PM
  3. Removing maf sensor 04+
    By HVACgtp in forum General Grand Prix Discussion
    Last Post: 12-05-2012, 01:54 AM
  4. Removing rear O2 sensor
    By Black18Ice in forum General Tech Discussion
    Last Post: 11-06-2009, 02:51 PM
  5. Removing 02 sensor true duels
    By Goany in forum General Tech Discussion
    Last Post: 01-11-2009, 10:11 PM
