Thread: Such a thing as to much timing?
Results 1 to 20 of 21
  1. #1 Such a thing as to much timing?
    Jan 2009
    Tallahassee, FL
    Just making sure on this one, is there such a thing as to much timing to a point where it's not beneficial? Right now I'm at 24*-26* at WOT and not knocking yet lol
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Such a thing as to much timing?
    Charles City, IA
    Yes you can run too much to where the fire line will out run the piston. I would stick to 18-20*.
    SMGPFC Two Nipple General
  3. #3 Re: Such a thing as to much timing?
    Drop the timing and pulley down...man I need chipped pistons...does that give me a better running car? LOL
  4. #4 Re: Such a thing as to much timing?
    Pennsylvania
    I think I remember a conversation detailing that anything above 22* WOT is useless. But I read that like... six months ago. In the meantime, I've been rather enjoyed by my beer. So, make of that what you will.
    "I ran up to 22*is timing on my old setup, never ran any better than when the timing was 20*. So I backed it back down to 20 and called it a day." - Reptile
  5. #5 Re: Such a thing as to much timing?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by TheOtherNick View Post
    Will do, I figured there was no point to go high, I'll bump it down 4* or so
    Already there lol
    And probably no pulley drop till I get a new motor
    77 Morris Garage B
  6. #6 Re: Such a thing as to much timing?
    Charles City, IA
    It all comes down to spark burn time and piston travel, which you need an ignition scope to figure out.
  7. #7 Re: Such a thing as to much timing?
  8. #8 Re: Such a thing as to much timing?
    Pennsylvania
  9. #9 Re: Such a thing as to much timing?
    I don't think he is going to run a smaller pulley since he has chipped pistons Nick
  10. #10 Re: Such a thing as to much timing?
    who cares? if it's already broken why not run it ragged?
  11. #11 Re: Such a thing as to much timing?
    Jan 2009
    Tallahassee, FL
    Already running ragged lol, don't have the money to purchase a pulley right now, maxing out what I can get out of this 3.6. Whenever I get a new motor it'll be a much better setup believe me.
    77 Morris Garage B
  12. #12 Re: Such a thing as to much timing?
    I'd just put the timing down to 20* and buy a new bottom end LOL
  13. #13 Re: Such a thing as to much timing?
    Jan 2009
    Tallahassee, FL
    I'm about to go do that actually. I'm not really scared of breaking anything else really, still runs like a top and does autox as well.
    77 Morris Garage B
  14. #14 Re: Such a thing as to much timing?
    AutoX'ing is pretty legit in a boat...I give ya kudos.
    I'd get headers and put a stock pulley on it with a high comp bottom end
  15. #15 Re: Such a thing as to much timing?
    Jan 2009
    Tallahassee, FL
    How did you know my plans?
    Thinking about going SSIC and see about running this 3.6 on that motor.
    77 Morris Garage B
  16. #16 Re: Such a thing as to much timing?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Sandman View Post
    High compression SSIC and headers you can run a 3.4 Easy. You will want to get 42.5's though
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  17. #17 Re: Such a thing as to much timing?
    Quote Originally Posted by 01gpgt01 View Post
    If only I could pull that off.
  18. #18 Re: Such a thing as to much timing?
    Kansas
    Quote Originally Posted by That Canadian Guy View Post
    Diddo
    SOLD 1999 GT Silvermist TS
  19. #19 Re: Such a thing as to much timing?
    SE Level Member Phantom's Avatar
    Independence KY
    IIRC 18-20* is best for a super charged motor and for a NA that the max timing is 20-26* WOT. Also I think that a degree or two can be added if running ethanol but I would not go much higher and only do it if you are running e85 all the time.
  20. #20 Re: Such a thing as to much timing?
    Hagerstown,Md
    I was running 21-23 WOT timing on a 3.4 with slight blips under .3 with a 11.8-12.1 afr
  1. perhaps the best thing ive ever seen... ever.
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 08-11-2010, 02:54 PM
  2. another thing i noticed...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-01-2009, 11:15 PM
  3. such thing as bad gas?
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2009, 03:56 PM
  4. Am I doing the right thing?
    By SlowM90 in forum The Rant Forum
    Last Post: 04-24-2009, 07:26 PM
  5. is this a factory thing?
    Last Post: 10-18-2008, 11:01 PM
