Thread: No fuel cell 3?
Results 1 to 6 of 6
  1. #1 No fuel cell 3?
    Barksdale AFB, LA
    I'm curious. A member was looking over one of my scans and saw that fuel cell 3 never comes up. Even when I go to 99.63% TP even though PE is set to come on at 30% TP.
    The PT's log just shows fuel cell 4, but the STFTs and LTFTs lock to zero... Weird. Anyone know why my PCM won't go to fuel cell 3?
    2009 Subaru Impreza WRX STI
  2. #2 Re: No fuel cell 3?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Is the care going into PE? I have never scanned a N/A car before so I don't know if they are different or not. Can't imagine they would be. Also what fuel cell is it in at WOT?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: No fuel cell 3?
    New Salem, ND
    Posting just for reference because I couldn't remember them all.
    0 -- Idle
    1 -- Decel
    2 -- Light Load / Engine Not Running
    3 -- High Load
    4 -- Med Load
  4. #4 Re: No fuel cell 3?
    Barksdale AFB, LA
    I get fuel cell 2 and 1 easily enough. 2 comes in with very light throttle (cruising), 1 for decel, and 4 comes in with moderate acceleration (over 5-6% TP) all the way to WOT. Never a cell 3. I do have PE as my LTFTs and STFTs go to 0 right at 30% TP just like the bin file is set.
    I searched on the Powrtuner forums and found some posts that at some point it would seem that cell 3 became exclusive to boosted applications. A SS M90 kit member who still has the L36 MAP says he has never seen cell 3 on his car (2002 Imp LS). Nor on any other L36 that he has gotten his hands on.
    So, it would seem that it is normal.
  5. #5 Re: No fuel cell 3?
    New Salem, ND
    Kind of what I thought but I had never heard of it until now. Does the car seem to run fine otherwise?
    BTW any plans to go with some sort of forced induction setup?
  6. #6 Re: No fuel cell 3?
    Barksdale AFB, LA
    Quote Originally Posted by Andrew_99GTP View Post
    Well, I still have a mostly stock tune with transmission modifications. It doesn't have problem running, but it needs some tweaking.
    Not for the time being. I decided to shelve the top-swap idea for a while.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Gotta read this if you have a cell phone!!!!
    By 2Fast4U in forum Off Topic Discussion
    Last Post: 05-21-2008, 05:22 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
