Re: Jerry's Tuner Notebook -> Wikified
When following your directions in the VE tune, I noticed something
I opened up a HPT scan and exported data in .csv file
I exported my current MAF table in .txt file and made changes. I could then, using eddies, export back to .txt
HOWEVER
after I made exported changes made to VE, the only option in eddies is .csv file
I cannot load a csv file back into HPT table , only txt
what other options do we have?
Thanks
Using PT, I use an Excel workbook. I would give it to you, but...uh...my copy's corrupted. I'm looking for a fresh copy now. When I DO find it, I promise to fight my goldfish-like memory and try to remember to send you the link or email a copy to you or SOMETHING. Again, I've been told to use it for PT, not sure if it'd work with HPT.
No worries, sorry that I can't be of help to ya.
You guys are going to get a chuckle at what tools I use now and how I work...
I basically use 3 programs...
- HPTuners
- Eddie's TinyTuner
- the old original PowrTuner
The ONLY things that I use the HPT program for is to scan and to flash the PCM with... thats it, thats all.
I start from a standard BIN that the PT uses and do all the prep work on the file there (I have many basic sections exported that make preparing my bin faster ny using the drag and drop techniques that the PT software can do). I then make a ton of additional changes and then using TinyTuner, work in there with the tables that are available just in there, export this file to a BIN, and then because HPT can use BIN files (the same kind that either TinyTUner or the PT can output), I use that file to flash the file to the PCM.
However, if one day the HPT stops supporting BIN files, you are screwed. Also, if you did not start from a BIN file... you are again screwed (because the HPT format can only be used by the HPT format, not the TinyTuner, nor the PT program).
It is possible but quite difficult to extract a BIN file from the HPT file... I don't know how to do it, and know of only 1 person that does... and I totally avoid this by starting from a BIN file from the first step.
I use this method as it gives me the maximum flexibility and lets me use all tables possible.. but if you thought tuning with 1 application was complex, wait till you try to juggle 3... lol
As far as the functionality of the TinyTuner is concerned, just go to clubgp.com, to the PCM tuning section and ask Eddie there directly, he still visits that forum now and then and may have a different work-around there for you.
Because of how close everything is to our house and how busy things tend to get, it's taking forEVER to get these MAF tunes done so I can finally get on to actual tuning. There's no quick AND safe way around it, is there? At WOT, at 94mph (going from 45-107.5mph), I have 8*KR, LTFT said 9.375, STFT reported 0, Spark was 20.5*.
My understanding is you need an older version of HPT that will let you save as a BIN file.
As to where someone might acquire that, I'm unawares.
I get the .bin from my cars by reading the PCM using PT. Does HPT have that option? The stock .bin can be found at:
Board Message
CAUTION: you need a profile to access that d/l. Follow this link to find out how to access the site:
ClubGP Message Forum troubleshooting
If you are using a HPT, the best place is to get a BIN from is to have the HPT program read your PCM. It is locked down a lot more than the PT software, and gets very problematic depending on the license you are using. For example, if your license is for your car only, using a bin from another PCM is not going to work as the serial numbers from the 2 PCMs are not the same. If you lived close to someone with a PT, just get them to read out your PCM, you save that file in 20 different physical locations (lol), then you are pretty much good to go.
With the PT, there are a lot less "restrictions", and it is not a problem, however, the scanning abilities of the PT kinda suck and of course, there is no longer any development going on to advance it.
Something that we were talking about last night was whether or not PT can edit VIN/Serial Numbers to a bin and then give it to a HPT for upload. I'm about to post on the Club and at the DHP forums. I already have his bin and VIN and SN.
It cannot, but if you had a hex editor and knew where to look, it may be possible.
Im so glad I came over and found these updated links. Everything over on the DHP forums seems to be broken up or mislinked
So The link for Jerry's Turner Notebook takes me to a site and tries to install some spyware etc.....might want to try to fix the link again....
CRU1Z3R
Look through the thread, seems no one is taking care of the WIKI anymore, so no one can fix it. Use the link to the original site that I put back up for you guys.
JUST AN FYI: THE JERRY TUNER NOTEBOOK SITE IS SAID TO HAVE VIRUS'S DETECTED BY GOOGLE.
Google Safe Browsing diagnostic page for wiki.opentuner3800.com
Safe Browsing
Diagnostic page for wiki.opentuner3800.com
What is the current listing status for wiki.opentuner3800.com?
Site is listed as suspicious - visiting this website may harm your computer.
Part of this site was listed for suspicious activity 1 time(s) over the past 90 days.
What happened when Google visited this site?
Of the 5 pages we tested on the site over the past 90 days, 2 page(s) resulted in malicious software being downloaded and installed without user consent. The last time Google visited this site was on 2012-05-22, and the last time suspicious content was found on this site was on 2012-05-02.
Malicious software includes 6 scripting exploit(s).
This site was hosted on 1 network(s) including AS26347 (DREAMHOST).
Has this site acted as an intermediary resulting in further distribution of malware?
Over the past 90 days, wiki.opentuner3800.com did not appear to function as an intermediary for the infection of any sites.
Has this site hosted malware?
No, this site has not hosted malicious software over the past 90 days.
How did this happen?
In some cases, third parties can add malicious code to legitimate sites, which would cause us to show the warning message.
Next steps:
Return to the previous page.
If you are the owner of this website, you can request a review of your site using Google Webmaster Tools. More information about the review process is available in Google's Webmaster Help Centre.
Update
Myprixxx
Wanted to personally thank you for all the work that went into this. Working on my first big tune by myself, and ive read the notebook over and over. Simplifies things so that they make sense. Awesome job on this, all the way around
Hate to break it to you, but its just plain wrong.
