Thread: Dhp Pcm
Results 1 to 9 of 9
  1. #1 Dhp Pcm
    GT Level Member GOINDEF's Avatar
    Holly, MI
    ok I recently bought my buddies DHP PCM from him to use on my grand prix, but im a little hesitant still. I was wondering if it's going from one basically stock GP to another, is there any reason to worry? we both have CAI, and thats about the extent. Next month im going to be replacing the ubend and the cat, but probably not much else than that. Is everything cool to use it?
  2. #2 Re: Dhp Pcm
    Barksdale AFB, LA
    Well, without reprogramming the VIN in the PCM to yours, its not going anywhere...
    2009 Subaru Impreza WRX STI
  3. #3 Re: Dhp Pcm
    Holly, MI
    so I pretty much cant use it til i get my VIN programmed into it? see i thought that that might be the case, but he used it after buying it from a previous GP owner with no problems except the different thermostat code
  4. #4 Re: Dhp Pcm
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by Sabrewings View Post
    at the very least it will need a CASE learn...
  5. #5 Re: Dhp Pcm
    Barksdale AFB, LA
    Quote Originally Posted by Reptile View Post
    Maybe this is an Impala thing, but if the VIN in the PCM doesn't match the VIN in the BCM the PCM won't start as a security feature.
  6. #6 Re: Dhp Pcm
    Kansas City, MO
    It's possible it could just be in the Impalas. I've never had a big issue with them in the GP's.
  7. #7 Re: Dhp Pcm
    Barksdale AFB, LA
    Probably is a Chevy thing then. Similar thing with the radio (programmed to VIN match with the BCM and will lock out if a mismatch occurs).
  8. #8 Re: Dhp Pcm
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    hook it up and see what happens... some will run kinda cruddy, if thats the case, take it to the dealer or someone with a Tech II and have a Case learn run, if it runs fine after installing it... you do not actually ahve to do a case learn
  9. #9 Re: Dhp Pcm
    Holly, MI
    Well i emailed DHP and they said as long as its from the same kind of vehicle and a pre 04 vehicle then there shouldnt be anything wrong and everything will work
dhp, pcm
