Thread: 97.5 pcm to 98 swap?
Results 1 to 13 of 13
  1. #1 97.5 pcm to 98 swap?
    NY
    Is it possible to swap a 98 and newer pcm into a car using a 97.5 style pcm that has the knock module integrated in it?
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
    PA
    Not sure about the regal. But many people have done a swap from 97 style GTP to 98 style GTP. So assuming that the 97.5 regal PCM is similar to the 97 GTP PCM, then yes, it can be done.
    But like I said, I cannot say for sure. There are a couple threads on the other forum that I have bookmarked and might help you. Or check out this page that has the harness swap for GTPs info on it.
    2001 GSE
    NY
    thanks..I'll have to look more into it. You really have to change the harness hu? Can't repin the connector on the original Plug?
    PA
    Quote Originally Posted by monte0 View Post
    No, I don't think so. Again, I have never done this, but I believe you just have to use the connectors from a 98+ harness, pull all the pins from your 97 connectors, and push them into the 98+ connectors, and then use a 98+ PCM. Again, not 100% sure, but I have some links to the other forum...but didn't know if I should put them up or not...
    2001 GSE
    Aurora, Colorado
    Quote Originally Posted by Zef_66 View Post
    I think the pinout information would be great info. And since nobody wants any forum fights, and this is PCM related, you could post it on the tuner notebook site as links for now and maybe we could integrate it into the tuner notebook.
    Just a thought.
    PA
    Quote Originally Posted by shor0814 View Post
    Just a thought.
    I would if I could figure out where to put the links...or how to add them...hmm...
    2001 GSE
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    First, visit Main Page - OpenTuner Notebook and register/log in.
    Then visit View source - OpenTuner Notebook and start posting away!!
    NY
    that wouild be great!
    Elk Grove Village, IL
    Why are you trying to swap it?? Just curious. I know back in the day the 97 was a bastard child but in todays age and the tools we have, it shouldnt be a problem. Im gonna be running my 97 PCM. I even bought a spare one just in case the one I have now fries.
    Williamsport, PA
    No problem. Thanks for the info. I added a link to your page on the main page of the wiki as well.
    PA
    Quote Originally Posted by TyroElite View Post
    Thanks Lyle!
    2001 GSE
  1. Seat Swap: 04+ to 97-03[*]
    By LowlyfeGTP in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2013, 03:32 PM
  2. 1986 Oldsmobile Cutlass L67 Swap
    By Trannyman95 in forum Transplants
    Last Post: 08-22-2012, 04:29 PM
  3. 1988 Buick LeSabre T-Type L67 swap
    By Rocketman69 in forum GM H Body
    Last Post: 08-07-2008, 12:12 AM
  4. Top Swap Section
    By indy99gpgt in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 05:53 PM
  5. 1992 Cadillac STS L67 Swap
    Last Post: 12-13-2007, 04:34 PM
