Thread: Cant write file to PCM Please help
Results 1 to 11 of 11
Kasey Cant write file to PCM Please... 10-13-2010, 06:03 PM
Lawngoose Re: Cant write file to PCM... 10-13-2010, 06:42 PM
Kasey Re: Cant write file to PCM... 10-13-2010, 08:07 PM
Kasey Re: Cant write file to PCM... 10-14-2010, 07:49 PM
Lawngoose Re: Cant write file to PCM... 10-14-2010, 07:52 PM
Kasey Re: Cant write file to PCM... 10-14-2010, 10:39 PM
Lawngoose Re: Cant write file to PCM... 10-15-2010, 08:10 AM
BillBoost37 Re: Cant write file to PCM... 10-15-2010, 09:12 AM
Whiplash Performance Re: Cant write file to PCM... 10-15-2010, 05:40 PM
CalEditor Re: Cant write file to PCM... 10-21-2010, 06:25 AM
Kasey Re: Cant write file to PCM... 10-22-2010, 09:20 AM
  1. #1 Cant write file to PCM Please help
    Acworth, Georgia
    I have a 2000 Grand prix GTP. So my first problem was that I couldnt write the file i had on my car because of an invalid os/vin error. I email hpsupport and said that the file cant be fixed because it was a previously written file from powertuner i think. I got a stock .bin file from someone and I tried to write it but it failed and said a os/vcm error I think.. Think it was the first step. If I get a correct .hpt file will I be able to write to my car then. Also is there a way Ill be able to switch all data from my old file to a stock file using compare in like one easy step?
  2. #2 Re: Cant write file to PCM Please help
    Outer Space
    Quote Originally Posted by Kasey View Post
    Using HPT ... can you read the OSID # ? If so, shoot it to me.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Cant write file to PCM Please help
    Acworth, Georgia
    how do I get that. Im at work now so I wont be able to look at my car until tomorrow.
  4. #4 Re: Cant write file to PCM Please help
    Acworth, Georgia
    ok my osid # is 9352809. How can you help me with that man.
  5. #5 Re: Cant write file to PCM Please help
    Outer Space
    Dude, that OSID is for a 98 GTP. Check your email, I sent you a gift. Try the new one. Only other thing I know to do is to program your VIN in there and try.
  6. #6 Re: Cant write file to PCM Please help
    Acworth, Georgia
    Ohh man thank you so much. Ive been trying to get this for weeks and finally it works. What exactly did you do?
  7. #7 Re: Cant write file to PCM Please help
    Outer Space
    I gave you a file with the OSID that you needed. Glad it works now
  8. #8 Re: Cant write file to PCM Please help
    HPT verifies that the OS (operating system) ID matches vailid software for the year that you are loading it into.
  9. #9 Re: Cant write file to PCM Please help
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    If you want to compare files there's actually a compare option and it will highlight difference between the two files
    It's on the menu bar.
    Just open up the first file you're going to compare
    click the folder with the * on it and open the second compare file.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  10. #10 Re: Cant write file to PCM Please help
    Rock Hill SC
    How far are you from Rock Hill
  11. #11 Re: Cant write file to PCM Please help
    Acworth, Georgia
    Quote Originally Posted by CalEditor View Post
    Don't know. I'm over in Sumter but I've figured everything out. At least for the transmision. I'll handle timing and fuel another day.
  1. BIN File
    By Dragon1972 in forum Off Topic Discussion
    Last Post: 09-10-2010, 04:51 AM
  2. Does anyone have a 01 GTP stock pcm file
    By gtpracer0186 in forum PCM Tuning
    Last Post: 09-02-2010, 06:13 PM
  3. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
  4. pre made bin file.
    By blowfishRus6 in forum PCM Tuning
    Last Post: 04-25-2009, 01:50 AM
  5. Need 1.5 Bin File for 2001 GTP
    By rynoman03 in forum PCM Tuning
    Last Post: 02-20-2008, 01:01 PM
