Thread: Buying a Tuned PCM from ZZP
Results 1 to 17 of 17
  1. #1 Buying a Tuned PCM from ZZP
    SE Level Member speedy2's Avatar
    NW Florida
    I've seen that their PCM's are now $125
    I'm looking to get one, but not sure when I should do it. I have an '05 Comp G. 100% stock right now. My question is, is it ok to get a PCM tuned for a 3.4" setup while the car is still stock? I'm wondering because I will not be buying all the mods together. $125 seems pretty cheap for a tuned PCM, so I'm thinking I should jump on it.
  2. #2 Re: Buying a Tuned PCM from ZZP
    Outer Space
    If you can find a local tuner, I got a stock 06 PCM you can have for cheap.
    However, I wouldnt run a can-tune for stuff you don't have on your car yet.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Buying a Tuned PCM from ZZP
    Topeka, KS
    Don't run a ZZP tune your car will hate you. Ask bluegtp91.
  4. #4 Re: Buying a Tuned PCM from ZZP
    Pennsylvania
    Tune for pure stock right now, re-tune after important mods. Install freshly tuned pcm's with pulley drops. That being said, installing a 3.4 tune on a 3.8 pulley will probably skull**** your engine.
    ZZP's quality of tune has been suspect in the past, but there are some, like VictorSmalls, that are thrilled with theirs.
  5. #5 Re: Buying a Tuned PCM from ZZP
    Donating Users
    GRAND RAPIDS, MI
    I recently purchased a Zzp pm and my converter dont lock up anymore
    2000 Grand Prix SE: Knocking rod mod and broken timing chain mod. L67 coming soon!
  6. #6 Re: Buying a Tuned PCM from ZZP
    Do what^^
    Agreed though NA...it is hit and miss...one of my good buddy's had a intercooled '97 GTP and his ran like a raped ape for what it was. I however, had 6 of them...all stuck in prgramming mode...and eventually toasted my engine. Just buy a DHP PCM and never have that issue...get them from 3800Performance.
  7. #7 Re: Buying a Tuned PCM from ZZP
    NW Florida
    Stay away from ZZP PCM's? Alrighty Then. That's all I needed to hear. Thanks guys. No local tuner here. I'm in a very rural area. But, I am near Panama City if anyone knows a tuner there. But, I don't think modded GTP's are too common here.
    This is the shop
    http://www.panhandleperformance.com/
    They seem to specialize in Fords. Every car in their Chassis Dyno gallery is a Ford. lol
  8. #8 Re: Buying a Tuned PCM from ZZP
    Check out the link in my sig too if you haven't already for a little more info you might be lookin' for otherwise mang.
  9. #9 Re: Buying a Tuned PCM from ZZP
    Donating Users
    South Deerfield, MA
    Noticed you're talking about a 3.4 pulley on your 05 Comp G. Just wanted to make sure you're safe and don't put a 3.4 on without supporting mods. A 3.6 on a Gen V supercharger is about equal to a 3.4 on a Gen 3 car. The standard headers, intake, and plugs won't support a 3.4 on your car.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  10. #10 Re: Buying a Tuned PCM from ZZP
    in all reality all off the shelf tunes are hit or miss. one will end up working great on one car while the same pcm will work like crap on another. this is why the make scanners. you still need to tweak your setup so the tune works for you and your car. this is why a custom tune is always the way to go if possible.
    i seriously dont know how someone has not started e-tuning yet. they could make boat loads of cash. it would require someone knowing how to tune and sending out BIN files for people. however, the person getting the tune would need a way to flash the tune and log it to send the log back to the tuner so they could tweak it. its literally all the rage with the import cars and anyone that doesnt it makes lots of money doing it.
  11. #11 Re: Buying a Tuned PCM from ZZP
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Quote Originally Posted by SlowNA06 View Post
    I love mine. Had problems with other brands in the past, but boxed tunes are hit or miss.
    Originally ran a basic bolt on N/A tune from ZZP for years and was very happy with it. Now running a turbo tune and could not be happier.
    Retired
    Turbo'd
  12. #12 Re: Buying a Tuned PCM from ZZP
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    My ss m90 tune on my car from them was pretty decent. Trims looked good decent timing, had some part throttle KR though. But I was satisfied
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  13. #13 Re: Buying a Tuned PCM from ZZP
    Jan 2009
    Tallahassee, FL
    Custom tune is best. I bought a PCM off someone that had a DHP tune on it and my car wasn't really happy with it. I'm pretty close to you and if I had a tuner and knew how I'd help you out. I think that there is a guy in PC who does have a tuner and might be able to help you out.
    Red Comp G right? Rode down to Whorelando with me
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  14. #14 Re: Buying a Tuned PCM from ZZP
    NW Florida
    I've read it a couple times.....
    Quote Originally Posted by Silver GTP View Post
    I forgot about that. I guess my setup would be a 3.6" then. Unless I add maybe rockers and an intercooler right? Or do you guys suggest more for a 3.4" on an '05 car.
  15. #15 Re: Buying a Tuned PCM from ZZP
    Donating Users Tengis's Avatar
    Houston
    I tuned a locals 04 CompG with nothing but a downpipe, PEMs, an intake, and a 3.4 as major mods. Had a 180* tstat, Autolite 104s, and some PRJ spark plug wires. I got him running knock free wide band tuned with a decent AFR and acceptable timing.
    I can do mail order PCM tuning if anyone is serious . I have an extra Powrtuner I can ship you if you put down a deposit and upon shipping it back you will get your deposit back.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  16. #16 Re: Buying a Tuned PCM from ZZP
    NW Florida
    Quote Originally Posted by Tengis View Post
    I may go this route. If you're talking about knock free with those few mods, I'd be willing to take a chance with all the mods I have planned. Although, still checking for KR as well.
  17. #17 Re: Buying a Tuned PCM from ZZP
    Houston
    Also, for the record, this post is retarded:
    A 3.4 tune is no different then a 3.8 tune... except a higher part of the MAF table is used at wide open throttle. If I tune someones car good on a 2.8 then they should be able to run any pulley size bigger then that because the lower sections of the MAF table SHOULD be tuned/smooth enough that AFR is essentially not effected.
    That being said, an after market PCM/tune off the shelf will run richer then a stock tune and realistically SHOULD be safer since I believe timing is even lowered a bit. Of course you end up with all of the other benefits of the tune as well: fan settings, torque management stuff, rev limiter, speed limiter... and all that ****.
    Satin Purple 97 GTP
  1. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  2. On The Way From Buying My GP..
    By EarlyGTDriver in forum Track Sessions and Kills
    Last Post: 08-27-2009, 08:23 PM
  3. Buying a GTP
    By Rod in forum Introductions/Noob Questions
    Last Post: 06-21-2008, 09:43 PM
  4. Buying a DHP PT
    By Sabrewings in forum General Tech Discussion
    Last Post: 04-13-2008, 08:37 AM
