Thread: Timing Drops To Around 0 After Shift? Torque Management?
Results 1 to 6 of 6
  1. #1 Timing Drops To Around 0 After Shift? Torque Management?
    SE Level Member Biggie's Avatar
    Williston, ND
    After the car shifts it just loses all power for about a second or 2 and then it comes right back. Is this torque management?
    Here is the scan.
    transmissionscan from biggie -- Scan Depot dot net
    Here is a video of it happening.
    tachnotiming.flv - Video - Photobucket - Video and Image Hosting
    What should I change to get rid of this?
    THANKS!
    XP, Ported: Heads, Blower, 3.0, 42lb Inj., Pacesetters, JP Double Roller Timing Chain, 105 Springs, 3" Exhaust, 3.5" Intake, AL 103s, Powertuner, AEM WB, Input Shaft, 7/8th Chain, 3k Stall, ZZP Pump Shaft + more stuff.
  2. #2 Re: Timing Drops To Around 0 After Shift? Torque Management?
    Williston, ND
    I went back to one of my really old tunes and it has fixed the problem. Time to get this thing tuned in as the race season is only a few weeks away!
  3. #3 Re: Timing Drops To Around 0 After Shift? Torque Management?
    TDCRacing
    Guest
    get rid of tm all together or you may always have issues with kr and timing like that....you got a preety good mod list...take advantage of it
  4. #4 Re: Timing Drops To Around 0 After Shift? Torque Management?
    TDCRacing
    Guest
    If your going to keep some tm......change the knock recovery rate a little and it should also help with that....you said you switched tunes....do you have any kr that you didnt before? does that tune have tm disabled? just curiouse
  5. #5 Re: Timing Drops To Around 0 After Shift? Torque Management?
    Williston, ND
    I do have KR now. But it is a pretty old tune. I put it on the car for testing purposes, haven't really driven it much since. I plan on tuning all this week.
  6. #6 Re: Timing Drops To Around 0 After Shift? Torque Management?
    TDCRacing
    Guest
    Well what i meant was do you have kr now that you didnt before? new tune vs. old tune
  1. N/A L67 timing differences with/vs L36?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 12:51 AM
  2. 5 Minute Management Trainning
    By webracin in forum Off Topic Discussion
    Last Post: 02-15-2008, 02:33 AM
  3. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
