Thread: PUlled down.Take a peak at scans please
Results 1 to 3 of 3
  1. #1 PUlled down.Take a peak at scans please
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Mods in sig. I was running a 3.6 pulley went to a 3.5. I have a header leak on the crossover rear collector and the front header. Im fixing that later this week. I get a insufficient switch CEL, and its maxing LFT's from the 02 in the exhaust. Anyways Im thinking I need to add maybe 2 percent 9,000HZ and up. What do you think? Timing was low because it was hot out today(high Iacs) Thanks for looking
    3.5 pulley scan NannyLog(04.11.2010_00.17.25). from gpgt01 -- Scan Depot dot net
    3.6 pulley scan NannyLog(04.09.2010_18.59.23). from gpgt01 -- Scan Depot dot net
    3.5 pulley scan NannyLog(04.12.2010_00.55.54). from gpgt01 -- Scan Depot dot net
    3.5 pulley scan http://www.scandepot.net/viewscan.php?pk=5136
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: PUlled down.Take a peak at scans please
    Outer Space
    Your knocking up to 2*, also are you running a rear o2 sensor or sim? There is a cat diagnostic test (occurs on 01+) that makes you go +16.4 ...
    However, I would get that exhaust fixed and see it your still 16.4... I think you need to address that before dropping pulley sizes.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: PUlled down.Take a peak at scans please
    Hagerstown,Md
    02 is Hooked up andin exhaust. Just doesnt have a cat.The PCM was a ZZP tuned pcm. I think they set the code to non report.Ive just made Maf changes and Timing changes as Ive added mods and dropped pullies I need to check with my HP tuner when I get it back from a friend I let borrow it. The 16.4 fuel trims didnt start untill my car tossed a p1133 code. I have leaks at the crossover front manifold and rear collector. so I assume thats why.
  1. So who got pulled over on New Years..I Did
    By JessinaterGTP in forum Off Topic Discussion
    Last Post: 01-01-2010, 10:02 PM
  2. uploading scans?
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 09-28-2009, 12:19 AM
  3. Replies: 34
    Last Post: 08-29-2009, 02:39 PM
  4. Replies: 5
    Last Post: 04-08-2008, 02:28 AM
