Thread: Hey someone take a look at these scans for me...opinions needed
Results 1 to 6 of 6
  1. #1 Hey someone take a look at these scans for me...opinions needed
    TDCRacing
    Guest
    hey if someone wouldnt mind looking at these scans for me and see if there is any advice that could be given to me....such as looks like you could get a little more timing from 2000+ or a maf tune ect. ,what could be done to get rid of the little kr that i do have and anything else that may help me out...thanks...
    one of the scanns was done shortly after the car was warmer up to operating temp (160 t-stat) with 87 octane and the other was with 93 octane
    mods in sig
  2. #2 Re: Hey someone take a look at these scans for me...opinions needed
    TDCRacing
    Guest
    ok some one now tell me if it is possible to upload a scan to this site from hpt. what format does it have to be in and how do i do it...
  3. #3 Re: Hey someone take a look at these scans for me...opinions needed
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    upload the scan to Scan Depot dot net and then post a link to the scandepot page.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  4. #4 Re: Hey someone take a look at these scans for me...opinions needed
    TDCRacing
    Guest
    Thanks dude it will be up in a second
  5. #5 Re: Hey someone take a look at these scans for me...opinions needed
    TDCRacing
    Guest
    ok ANOTHER question. how do i change the format of the scan to csv so i CAN upload it into scan depot?
    Shoot this thread looks like it should of been on ''how to post a scan on gpf'' lol
  6. #6 Re: Hey someone take a look at these scans for me...opinions needed
    New Salem, ND
    I use a pt and when I save a log it saves as a CSV, not sure what hpt saves as. Maybe you can choose CSV when you are saving it? Ok the reason pt saves it as a CSV is because I have it set that way in the options, so look under the logging options ( if that is what hpt calls it).
  1. When is the Non-HD to HD Trans Upgrade Needed
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2008, 03:53 PM
  2. ATTN Farnsworth - tool info needed
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-14-2008, 10:54 AM
  3. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
  4. Before and After (Opinions Wanted)
    Last Post: 01-16-2008, 11:04 PM
