Thread: AFR question
Results 1 to 7 of 7
  1. #1 AFR question
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    What kind of AFR am I looking for at WOT? What about just cruising. Yes I have a wideband. Thanks
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  2. #2 Re: AFR question
    you want about 11.4-11.6 for the best power range. if you want to lean out further because youre only on a 3.4 it might work out, but i always went for a conservative amount of fuel with more timing.
  3. #3 Re: AFR question
    Jan 1970
    Maquoketa, Iowa
    Yep and 12's are lean and 10's are rich.
  4. #4 Re: AFR question
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    Boost = 11's
    N/A = Mid-High 12's
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  5. #5 Re: AFR question
    Apr 2009
    Phoenix, AZ
    Can running too rich casue KR?
  6. #6 Re: AFR question
    Thornton, Colorado
    Quote Originally Posted by 2001GTP View Post
    Yes
  7. #7 Re: AFR question
    yes, yes it can.
  1. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  2. Question: Supercharger question.....
    By nmaponte in forum General Tech Discussion
    Last Post: 03-12-2009, 01:04 PM
