Thread: Evaporative System - Incomplete
Results 1 to 20 of 20
  1. #1 Re: Evaporative System - Incomplete
    PA
    I don't have to worry about codes because my car doesn't get inspected for emissions or codes.
    But I believe you can set the codes to "Non-reporting" with your tuner. Then, even if something is wrong, it won't even report it to the PCM, so nothing is stored. If you just turn off the code, the PCM will still store the code, but just won't turn on the light.
    Try changing the said codes to non-reporting, clear everything, and make sure you drive 150-200 miles before inspection. All should be good.
    2001 GSE
  2. #2 Re: Evaporative System - Incomplete
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I'll give it a shot. I was worried since this is an item that is hard coded and with either read incomplete, complete, or NA. Anything but complete and you fail.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. best Exhaust System
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2013, 08:53 AM
  2. Catz Zeta system
    By Berger in forum Visual/Body Modifications
    Last Post: 02-29-2008, 02:29 AM
  3. Gm Navigation system
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 02-13-2008, 09:17 PM
  4. My system right now
    By Grandprixboy1224 in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2008, 05:04 PM
