Thread: Actual Timing > Spark Table
Results 1 to 9 of 9
  1. #1 Actual Timing > Spark Table
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I was scanning on the way to work this morning, tweaking a few things. I noticed that the actual timing was typically several degrees higher than what I have in the spark table. What is influencing this? At "gentle" cruising the timing actually got as high as 50° where the table was only 45-47°. WOT I had readings at 16-17° when the table was only 12-13°. It seems like an extra ±5° is going into the whole thing, and I am wondering if anyone knows why, or where this is coming from. Also, I recall most folks saying that 45° was the best/top/maximum that should be run (non-WOT) but I am curious where this number comes from as well.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  2. #2 Re: Actual Timing > Spark Table
    Jul 2008
    nj
    Well, the good spark table is only 1 table that is used in the calculation to determine the actual spark advance. I think the table that is adjusting the timing during your cruise is the EGR table. This adds timing when the egr is active. Keep in mind other tables are also affecting the timing like the air temp and coolant temp tables. Those are just 2 that come to mind. 50....I think that is the actual max timing allowed. I seem to think it was 48...I guess I am wrong. At WOT...I think the same tables are affecting your timing along with the spark afr table that everyone likes to zero out.
    HTH
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  3. #3 Re: Actual Timing > Spark Table
    Waynesboro, PA
    Quote Originally Posted by Damojo2003 View Post
    HTH
    EGR is disabled. IAT was probably 60-80°F, and coolant was 180-190°F...I do not think I have and adder in those tables anywhere near those temps.
  4. #4 Re: Actual Timing > Spark Table
    There are a bunch of modifier tables. IAT and ECT are a couple.
  5. #5 Re: Actual Timing > Spark Table
    Waynesboro, PA
    There are also spark modifiers for IAT and ECT .
    No way!
  6. #6 Re: Actual Timing > Spark Table
    Most IAT and ECT spark tables are setup so that they will only have an effect at temperature extremes (well, not extremes, but above/below normal temps).
    More common modifiers that are present, EGR and TCC spark.. TCC Spark taking timing away when tcc is applied. EGR spark adding timing when EGR is active.
  7. #7 Re: Actual Timing > Spark Table
    Bastard Reptile's Avatar
    Kansas City, MO
    I know I'm way behind here, but there is a table not visible to the DHP tuner. Dave showed me in HPT that there is a table that typically adds 6 degrees to the cruise timing all through the tables. The exact name escapes me at the moment, but it states in the description that it adds overall timing in conjunction to the timing table, good spark or bad spark.
  8. #8 Re: Actual Timing > Spark Table
    That would be AFR spark.. It adds timing based on current commanded AFR. Note, at stoich AFR, the value is 0 (no additional timing).. Number/value increases as AFR decreases. Stock values vary a bit depending on year.
    I think there are only like 7 AFR values/ranges.. The table is quite simple compared to the EGR and TCC spark tables.
  9. #9 Re: Actual Timing > Spark Table
    Charles City, IA
    SMGPFC Two Nipple General
  1. GT trans table
    By TheOtherNick in forum PCM Tuning
    Last Post: 05-24-2009, 12:03 PM
  2. MAF table?
    By GTP4 in forum PCM Tuning
    Last Post: 12-17-2008, 09:41 PM
  3. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  4. Replies: 9
    Last Post: 10-03-2008, 12:12 PM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
