Thread: just got my hp tuner...questions!!!!
Results 1 to 14 of 14
  1. #1 just got my hp tuner...questions!!!!
    TDCRacing
    Guest
    yup so like it says i finially got my hp tuner and it is shipping out tomorrow! The car is still stock (right now) and hence i will be tunning a stock car any way will someone with tuning experince tell me some things i can tune that will improve performance on a stock 99 gtp? i have been doing lots of reading and still am so try to explain yourself and also explain why i should be tuning this particular thing ex. timing,fuel ext. it is about 60's here so it is getting hot down here again...just thought i'd mention that.I understand i should do a scan first. and also do one often.
    Thanks
  2. #2 Re: just got my hp tuner...questions!!!!
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Look at the Sticky at the top called Jerry's Notebook, read over on the HPTuners site eveything you can, go to FullthrottleV6 and read Gary's tuning Guide 101.
    That should help out quite a bit, unless you are like me, and hard headed.
    The only advise I would give, is make sure your backup your stock bin in case you need to start over. Go slow, make small changes one at a time, so if your car doesn't like something you know what caused the issue.
    I have the HPTuners, but seek out the experts for help with mine. No way would I ever be able to catch up with the years of experience some of them have.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: just got my hp tuner...questions!!!!
    Oklahoma
    I havent done it much as I have not been able to spend a lot of time tuning. But what I do is as Lee mentioned, I have a full back up of my BIN file. Then I created a new folder, something along the lines of Tuning Diary. I then put a copy of my stock BIN file in there and work from that.
    Each time I made a change I save it as a new file with a revision number. For instance MyBINFile_v1. Then I also have a notepad file called something along the lines of BINFileRevisionHistory.txt. Each time I make a change to the BIN file and upload, I go in that notepad, add the new revision number and write notes as to what I did, why and what the results were. I suppose you could even go as far as to use a MS Doc file and put in links to scan files and so forth.
    The point to all this is that I can see EXACTLY what has been done over the course of time to the vehicle. I can also switch back to any previous tune if some issue should arise. Consider it a manual restore point if you will. I dont have to go in and edit the BIN file trying to guess at what all I may have changed, I just have to upload the last revision or any of the previous revisions before the issue showed up.
    Once you get to a point where all your revising is done and you have what you believe to be a solid tune, create a new folder and call it something along the lines of Base Tunes. Then save the BIN file as General or Base Tune. Then you can go back and start all over again if you want to create a track specific tune or highway tune and so on. Though I dont know how practical that is, but just something to consider.
  4. #4 Re: just got my hp tuner...questions!!!!
    TDCRacing
    Guest
    Hey thanks for the reply!! i have read jerrys tuner totebook several times but just couldnt understand some of the things they were talking about(probably because i dont actually have the tuner yet...its already shipped out though) but i will definitly check out garys tuning 101 because i dont belive i have read it yet.thanks again...
    synthetic.....thanks....i was thinking of doing the same thing you mentioned but didnt know if i could...good to know...do you have a link or some screen shots of how it is excatly done?where are the bin files stored? on your computer or on the hp tuner program? and once you have compleate bin files can you just flash the pcm with that file and then you will have that ''tune''?? ex. one for highway good gas milage 1/4 mile ect...?
  5. #5 Re: just got my hp tuner...questions!!!!
    TDCRacing
    Guest
    pretty much the only thing i can tune a stock car for is transmission shift points/pressure ect right or wrong? could i dip into timing if the kr is not too bad?
  6. #6 Re: just got my hp tuner...questions!!!!
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    Jerry guide is based off of the Powrtuner, although the principles are the same, whether right or wrong.
    Gary's guide is for the HPTuners and isn't as long or indepth.
    You can change so much with the HPTuners, I can't even tell you how much. Air, Fuel, Spark, shift points, timing advance, gearing, speed limiters, torque management, fan settings, DTC troyble code clearing or disabling,,,and a crap load more.
    2010 Camaro SS LS3
  7. #7 Re: just got my hp tuner...questions!!!!
    TDCRacing
    Guest
    looked for garys tuner 101 AND COULD NOT FIND IT...HAVE A LINK??? ALSO I KNOW THAT YOU CAN CHANGE A WHOLE LOT MORE THAN WE HAVE BOTH STATED BUT WHAT I WAS MEANING WAS WHAT WOULD BE BENEFITIAL TO A STOCK SETUP TO CHANGE?? JUST TRANSMISSION??....OR COULD I MESS WITH THE TIMING IF I DONT HAVE ANY KR?? I REALIZE MY OPTIONS ARE UNLIMITED AS FAR AS THE TUNING GOES BUT WHAT ARE MY OPTIONS AS FAR AS MY STOCK SETUP GOES??
  8. #8 Re: just got my hp tuner...questions!!!!
    St Louis MO
    Special VCM Controls
    Cylinder Balance: The cylinder balance test calculates % of efficiency using current RPM. RPM is gauged with all injectors running normally. Injectors are then cut 1 cylinder at a time and the new RPM is compared to the pre-test RPM to determine % of efficiency. To use this test the main scanner must be stopped. You must also control the IAC steps as well for consistency.
    Cylinder Balance Test - How-To
    Bring the engine up to full operating temp (at least 180*)
    Open the Scanner
    Sectect VCM Controls and then Special
    The scanner need to be connected but stopped and no log file opened.
    Set the IAC to around 800 to 900 RPMs
    Set the IAC steps to 60
    Click Begin
    Idle (IAC) Control RPM: Force a desired idle RPM.
    Idle (IAC) Control Steps: Force the IAC motor to this position. This control is also used for the cylinder balance test.
    CASE Learn: To use the CASE learn function please follow these steps:
    Put the vehicle into park (auto) or neutral (manual).
    Turn off all accessories and A/C.
    Apply the parking brake.
    Press the brake pedal. Keep the brake pedal depressed during the entire procedure.
    Press Begin.
    Gradually rev the vehicle to fuel cutoff (around 4000-5000 RPM's) over a period of about 4 seconds. When fuel cuts out, immediately release the throttle.
    Allow the engine to come back to an idle.
    Turn the ignition off for at least 15 seconds. This step is required for the VCM to store the newly learned configuration.
    2010 Camaro SS LS3
  9. #9 Re: just got my hp tuner...questions!!!!
    St Louis MO
    just some quick reading generalized
    Tuning Tips
    2010 Camaro SS LS3
  10. #10 Re: just got my hp tuner...questions!!!!
    TDCRacing
    Guest
    cool thanks for all the info and help....hey can u explain a cylinder ballance test in some other words maybe?? like for ppl that dont know what the hell there doing yet?? What is its purpose? lol sorry...and does anybody know about the map conversion to boost psi that was discussed above by any chance?
  11. #11 Re: just got my hp tuner...questions!!!!
    St Louis MO
    Not sure I can say much more than described.
    It is just a tool, and a very basic one at that. Since it cuts one cylinder out of the picture at a time, it allows you to see if there is a problem with that cylinder. All of the percentages should be within 3% of each other iirc. It's just fun to watch and feel the control over the engine. If one percentage is way off though, you will have to figure out what the problem is.
    I believe my cylinders, when tested, were all around 93%.
    As far as the brackets in the boost conversion, I believe the answer is yes, from other custom PID's I've seen. Try it out and let us know. If it doesn't work then it's not going to hurt anything.
    2010 Camaro SS LS3
  1. Jerry's Tuner Notebook -> Wikified
    By shor0814 in forum PCM Tuning
    Last Post: 06-01-2016, 05:24 PM
  2. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
  3. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
  4. New guy with questions
    By chuy53511 in forum Introductions/Noob Questions
    Last Post: 02-03-2008, 07:20 AM
  5. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
